[petsc-users] parallel PCASM
Matthew Knepley
knepley at gmail.com
Wed Dec 21 15:40:54 CST 2011
On Wed, Dec 21, 2011 at 3:30 PM, Reza Madankan <rm93 at buffalo.edu> wrote:
> Hi Matthew;
> Thank you for you quick reply.
> Sorry for the wrong terminology, it's just few days I started working with
> Petsc.
> The whole story is that I have a linear system Ax = b which I want to
> solve it using different preconditioners just to see the effect of each of
> those on the solution and residual error. I have already used PCJACOBI and
> PCILU to find the solution. I also would like to see the effect of using
> PCASM. PCASM on a single processor performs like PCILU, but its result
> will be different from PCILU if I implement it on multiple processors. So,
> I am trying to get it run for multiple processors case using the following
> command:
> mpiexec -np 2 ./pcasm
> but I get the error message that I showed before. Now my question is that
> how I can implement PCASM on multiple processors?
It is not ASM that is the problem. You have a bug in your code. Use
valgrind to find it.
The larger problem here is that you have completely misunderstood the point
of PETSc.
Whatever you do, never change your code to use a different solver. You
should play
with the PETSc examples for a while
cd src/snes/examples/tutorials
make ex5
./ex5 -snes_monitor -ksp_monitor -snes_view
$MPIEXEC -n 2 ./ex5 -snes_monitor -ksp_monitor -snes_view
$MPIEXEC -n 2 ./ex5 -snes_monitor -ksp_monitor -snes_view -pc_type jacobi
$MPIEXEC -n 2 ./ex5 -snes_monitor -ksp_monitor -snes_view -pc_type asm
Matt
Thanks again
> Reza
> On Wed, Dec 21, 2011 at 3:19 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Wed, Dec 21, 2011 at 2:12 PM, Reza Madankan <rm93 at buffalo.edu> wrote:
>>> Hello,
>>> I am trying to parallelize the ASM preconditioner while solving a linear
>>> system. For more detail, I have printed relevant parts of code in the
>>> following:
>> I have no idea what "parallelize ASM" might mean.
>> Below you likely have a bad value in b, the rhs you pass to the solver on
>> line 487 of your code.
>> Matt
>>> *static char help[]="Reading in a matrix\n";*
>>> * #include<stdio.h>*
>>> * #include<math.h>*
>>> * #include<stdlib.h>*
>>> * #include "petscvec.h" /* This enables us to use vectors. */*
>>> * #include "petscmat.h" /* This enables us to use Matrices. It includes
>>> the*
>>> * petscvec header file*/*
>>> * #include "petscksp.h" /* Now we can solve linear systems. Solvers
>>> used are*
>>> * KSP. */*
>>> * extern PetscErrorCode MyKSPMonitor(KSP,PetscInt,PetscReal,void*);*
>>> * int main(int argc, char **argv)*
>>> * /* Declaration of Matrix A and some vectors x*/*
>>> * Vec w, ypcq, mean_tmp, x, PzyTvec;*
>>> * Mat Ym, Y, Mean, Ypcq, YpcqT, Pzz, InnProd, Para, Pzy, PzyT,PzzT,K,
>>> KT, PK, PzzTMP, Pmat, XYmat, KY;*
>>> * FILE *fp, *fp1, *fp2, *fp3;*
>>> * PetscInt index,i,j,k, ns=16, nw=100, tindex_f=120, col,tind, mz, nz,
>>> its;*
>>> *printf("Enter number of sensors (ns):\n");*
>>> *scanf("%d",&ns);*
>>> *printf("Enter number of time steps (tindex_f):\n");*
>>> *scanf("%d",&tindex_f);*
>>> * PetscMPIInt size;*
>>> * PC pc;*
>>> * KSP ksp;*
>>> * PetscReal norm, tol=1.e-14;*
>>> * PetscBool nonzeroguess = PETSC_FALSE;*
>>> * PetscViewer mviewer;*
>>> * PetscScalar scalar,rhsy[ns*tindex_f*nw],rhsym[ns*tindex_f], rhsw[nw],
>>> Ymat[tindex_f*ns][nw], tmp, rhsp[2*nw], xvec[ns*tindex_f], pmat[4],
>>> xymat[2], rnorm;*
>>> * PetscErrorCode ierr;*
>>> * /* This part is needed for the help flag supplied at run-time*/*
>>> * ierr = PetscInitialize(&argc,&argv,(char*)0,help);CHKERRQ(ierr);*
>>> * ierr = MPI_Comm_size(PETSC_COMM_WORLD, &size);CHKERRQ(ierr);*
>>> * //if (size != 1) SETERRQ(PETSC_COMM_WORLD,1,"This is a uniprocessor
>>> example");*
>>> *PetscPrintf(PETSC_COMM_WORLD,"size is: %D\n",size);*
>>> *int nstindex_f=ns*tindex_f;*
>>> *ierr =
>>> PetscOptionsGetInt(PETSC_NULL,"-n",&nstindex_f,PETSC_NULL);CHKERRQ(ierr);
>>> *// Solution for K:*
>>> * ierr =
>>> * ierr =
>>> PetscOptionsGetBool(PETSC_NULL,"-nonzero_guess",&nonzeroguess,PETSC_NULL);
>>> CHKERRQ(ierr);*
>>> *// KSPMonitorSet(ksp,MyKSPMonitor,PETSC_NULL,0);*
>>> * ierr = VecCreate(PETSC_COMM_WORLD,&x);CHKERRQ(ierr);*
>>> * ierr = PetscObjectSetName((PetscObject) x,
>>> "Solution");CHKERRQ(ierr);*
>>> * ierr = VecSetSizes(x,PETSC_DECIDE,ns*tindex_f);CHKERRQ(ierr);*
>>> * ierr = VecSetFromOptions(x);CHKERRQ(ierr);*
>>> * ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);*
>>> *// ierr = KSPMonitorSet(ksp,PetscInt n,PetscReal rnorm, void *); *
>>> *// ierr = monitor(ksp,Int it,PetscReal rnorm,);*
>>> * ierr = MatTranspose(Pzz,MAT_INITIAL_MATRIX,&PzzT);*
>>> * MatAssemblyBegin(PzzT,MAT_FINAL_ASSEMBLY);*
>>> * MatAssemblyEnd(PzzT,MAT_FINAL_ASSEMBLY);*
>>> * ierr =
>>> KSPSetOperators(ksp,PzzT,PzzT,DIFFERENT_NONZERO_PATTERN);CHKERRQ(ierr);*
>>> * ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);*
>>> * ierr = PCSetType(pc,PCASM);CHKERRQ(ierr);*
>>> * ierr =
>>> KSPSetTolerances(ksp,1e-6,PETSC_DEFAULT,PETSC_DEFAULT,1e+9);CHKERRQ(ierr);
>>> * ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);*
>>> * if (nonzeroguess)*
>>> * PetscScalar p = 0.5;*
>>> * ierr = VecSet(x,p);CHKERRQ(ierr);*
>>> * ierr =
>>> KSPSetInitialGuessNonzero(ksp,PETSC_TRUE);CHKERRQ(ierr);*
>>> * ierr = MatTranspose(Pzy,MAT_INITIAL_MATRIX,&PzyT);*
>>> * MatAssemblyBegin(PzyT,MAT_FINAL_ASSEMBLY);*
>>> * MatAssemblyEnd(PzyT,MAT_FINAL_ASSEMBLY);*
>>> * ierr = MatCreate(PETSC_COMM_WORLD,&KT);CHKERRQ(ierr);*
>>> * ierr =
>>> MatSetSizes(KT,PETSC_DECIDE,PETSC_DECIDE,ns*tindex_f,2);CHKERRQ(ierr);*
>>> * ierr = MatSetFromOptions(KT);CHKERRQ(ierr);*
>>> * int ctr=0;*
>>> * for (ctr=0; ctr<2; ctr++)*
>>> * ierr = VecCreate(PETSC_COMM_WORLD,&PzyTvec);*
>>> * ierr = VecSetSizes(PzyTvec,PETSC_DECIDE,ns*tindex_f);*
>>> * ierr = VecSetFromOptions(PzyTvec);*
>>> * ierr = MatGetColumnVector(PzyT,PzyTvec,ctr);*
>>> * ierr = KSPSolve(ksp,PzyTvec,x);CHKERRQ(ierr);*
>>> * ierr = KSPGetIterationNumber(ksp,&its);CHKERRQ(ierr);*
>>> * ierr = KSPGetResidualNorm(ksp,& norm); *
>>> * printf("residual norm is=%e\n",norm);*
>>> * printf("iteration number is=%d\n",its);*
>>> * ierr = KSPView(ksp,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);*
>>> *// printf("%d\n", ctr);*
>>> * for (i=0; i<ns*tindex_f; i++)*
>>> * ierr = VecGetValues(x,1,&i,&xvec[i]);*
>>> * ierr = MatSetValues(KT,1,&i,1,&ctr,&xvec[i],INSERT_VALUES);*
>>> * MatAssemblyBegin(KT,MAT_FINAL_ASSEMBLY);*
>>> * MatAssemblyEnd(KT,MAT_FINAL_ASSEMBLY);*
>>> * MatTranspose(KT,MAT_INITIAL_MATRIX,&K);*
>>> * MatAssemblyBegin(K,MAT_FINAL_ASSEMBLY);*
>>> * MatAssemblyEnd(K,MAT_FINAL_ASSEMBLY);*
>>> * MatPtAP(Pzz,KT,MAT_INITIAL_MATRIX,1.0,&PK);*
>>> *//MatCopy(Pzz,PzzTMP,SAME_NONZERO_PATTERN);*
>>> * ierr = MatAXPY(Pmat,-1,PK,DIFFERENT_NONZERO_PATTERN);*
>>> * MatView(Pmat,PETSC_VIEWER_STDOUT_WORLD);*
>>> * ierr = MatAXPY(Ym,-1,Mean,DIFFERENT_NONZERO_PATTERN);*
>>> * MatAssemblyBegin(Ym,MAT_FINAL_ASSEMBLY);*
>>> * MatAssemblyEnd(Ym,MAT_FINAL_ASSEMBLY);*
>>> * ierr = MatMatMult(K,Ym,MAT_INITIAL_MATRIX,PETSC_DEFAULT,&KY);*
>>> * ierr = MatAssemblyBegin(KY,MAT_FINAL_ASSEMBLY);*
>>> * ierr = MatAssemblyEnd(KY,MAT_FINAL_ASSEMBLY);*
>>> * ierr = MatAXPY(XYmat,1,KY,DIFFERENT_NONZERO_PATTERN);*
>>> * MatView(XYmat,PETSC_VIEWER_STDOUT_WORLD);*
>>> *ierr = MatDestroy(&Mean);*
>>> *ierr=PetscFinalize();CHKERRQ(ierr);*
>>> * return 0;*
>>> I am using the following commands to compile and run the code:
>>> *mpicc pcasm.c -o pcasm -l petsc*
>>> *mpiexec -np 2 ./pcasm*
>>> But when I run the code I get the following error message which I don't
>>> know what it means.
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Floating point exception!
>>> [0]PETSC ERROR: Infinite or not-a-number generated in norm!
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: Petsc Release Version 3.2.0, Patch 3, Fri Sep 30
>>> 10:28:33 CDT 2011
>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: ./pcasm on a linux-imp named k07n14.ccr.buffalo.edu by
>>> rm93 Wed Dec 21 15:05:33 2011
>>> [0]PETSC ERROR: Libraries linked from
>>> /util/petsc/petsc-3.2-p3/linux-impi-mkl/lib
>>> [0]PETSC ERROR: Configure run at Fri Oct 21 08:36:23 2011
>>> [0]PETSC ERROR: Configure options --CC=/util/intel/impi/
>>> 4.0.3.008/intel64/bin/mpiicc --FC=/util/intel/impi/
>>> 4.0.3.008/intel64/bin/mpiifort --CXX=/util/intel/impi/
>>> 4.0.3.008/intel64/bin/mpiicpc--with-blas-lapack-dir=/util/intel/composer_xe_2011_sp1/mkl/lib/intel64
>>> --download-hypre=1 --with-debugging=0 -PETSC_ARCH=linux-impi-mkl
>>> --with-shared-libraries=1
>>> [0]PETSC ERROR:
>>> [0]PETSC ERROR: VecNorm() line 167 in src/vec/vec/interface/rvector.c
>>> [0]PETSC ERROR: VecNormalize() line 261 in
>>> [0]PETSC ERROR: GMREScycle() line 128 in src/ksp/ksp/impls/gmres/gmres.c
>>> [0]PETSC ERROR: KSPSolve_GMRES() line 231 in
>>> [0]PETSC ERROR: KSPSolve() line 423 in src/ksp/ksp/interface/itfunc.c
>>> [0]PETSC ERROR: main() line 487 in "unknowndirectory/"pcasm.c
>>> application called MPI_Abort(MPI_COMM_WORLD, 72) - process 0
>>> rank 0 in job 2 k07n14.ccr.buffalo.edu_51735 caused collective abort
>>> of all ranks
>>> exit status of rank 0: return code 72
>>> Could anyone help me on this problem? Thanks in advance for any help.
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111221/6be30362/attachment-0001.htm>
