[petsc-users] mumps freezes for bigger problems
Hailong Xiao
xiaohl1986 at gmail.com
Wed Dec 21 11:19:01 CST 2011
Hi Hong
I got the error from MUMPS.
When I run MUMPS (which requring scalapack) with matrix size (n) = 30620,
nonzeros (nz) = 785860,
I could run it. And could get result.
But when I run it with
nz=3112820
n =61240
I am getting the following error
17 - <NO ERROR MESSAGE> : Could not convert index 1140850688 into a pointer
The index may be an incorrect argument.
Possible sources of this problem are a missing "include 'mpif.h'",
a misspelled MPI object (e.g., MPI_COM_WORLD instead of MPI_COMM_WORLD)
or a misspelled user variable for an MPI object (e.g.,
com instead of comm).
[17] [] Aborting Program!
Do you know what happened?
Is that possible it is running out of memory?
On Wed, Dec 21, 2011 at 7:15 AM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Direct solvers often require large memory for storing matrix factors.
> As Jed suggests, you may try superlu_dist.
> With mumps, I notice you use parallel analysis, which is relative new in
> mumps.
> What happens if you use default sequential analysis with
> different matrix orderings?
> I usually use matrix ordering '-mat_mumps_icntl_7 2'.
> Also, you can increase fill ratio,
> -mat_mumps_icntl_14 <20>: ICNTL(14): percentage of estimated workspace
> increase (None)
> i.e., default ration is 20, you may try 50? (I notice that you already use
> 30).
> It seems you use 16 CPUs for "a mere couple thousands
> elements" problems, and mumps "silently freezes". I do not have this type
> of experience with mumps. I usually can solve sparse matrix of size
> 10k with 1 cpu using mumps.
> When mumps runs out of memory or gets other problems, it terminates
> execution and dumps out error message,
> not freezes.
> Something is wrong here. Use a debugger and figuring out where it freezes.
> Hong
> On Wed, Dec 21, 2011 at 7:01 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > -pc_type lu -pc_factor_mat_solver_package superlu_dist
> > On Dec 21, 2011 6:19 AM, "Dominik Szczerba" <dominik at itis.ethz.ch>
> wrote:
> >> I am successfully solving my indefinite systems with MUMPS but only
> >> for very small problems. To give a feeling, a mere couple thousands
> >> elements. If I only double the problem size, it silently freezes, even
> >> with max verbosity via the control parameters. Did anyone succeed here
> >> with big problems? Any recommendations for a drop-in replacement for
> >> MUMPS?
> >> Thanks for any hints,
> >> Dominik
> >> Options used:
> >> -mat_mumps_icntl_4 3 -mat_mumps_icntl_28 2 -mat_mumps_icntl_29
> >> Output:
> >> ****** FACTORIZATION STEP ********
> >> GLOBAL STATISTICS PRIOR NUMERICAL FACTORIZATION ...
> >> NUMBER OF WORKING PROCESSES = 16
> >> OUT-OF-CORE OPTION (ICNTL(22)) = 0
> >> REAL SPACE FOR FACTORS = 1438970073
> >> INTEGER SPACE FOR FACTORS = 11376442
> >> MAXIMUM FRONTAL SIZE (ESTIMATED) = 16868
> >> NUMBER OF NODES IN THE TREE = 43676
> >> Convergence error after scaling for ONE-NORM (option 7/8) = 0.21D+01
> >> Maximum effective relaxed size of S = 231932340
> >> Average effective relaxed size of S = 182366303
> >> REDISTRIB: TOTAL DATA LOCAL/SENT = 1509215 22859750
> >> GLOBAL TIME FOR MATRIX DISTRIBUTION = 0.8270
> >> ** Memory relaxation parameter ( ICNTL(14) ) : 35
> >> ** Rank of processor needing largest memory in facto : 0
> >> ** Space in MBYTES used by this processor for facto : 2017
> >> ** Avg. Space in MBYTES per working proc during facto : 1618
Hailong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111221/8ee3d5ac/attachment.htm>
