[petsc-users] -log_summary problem
Tue Dec 20 19:38:27 CST 2011
On Tue, Dec 20, 2011 at 19:35, Max Rudolph <rudolph at berkeley.edu> wrote:
> When I run my code with the -log_summary option, it hangs indefinitely
> after displaying:
> Average time to get PetscTime(): 9.53674e-08
> Average time for MPI_Barrier(): 0.00164938
> Is this a common problem, and if so, how do I fix it? This does not happen
> when I run the example programs - only my own code, so I must be at fault
> but without an error message I am not sure where to start. I am using
> petsc-3.1-p7. Thanks for your help.
Are all processes calling PetscFinalize()?
How did you set -log_summary? It should be provided at the time you invoke
PetscInitialize() on all processes.
Try running in a debugger, then break when it hangs and print the stack
trace.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111220/34409386/attachment.htm>
