[petsc-users] Solving indefinite systems with iterative solvers
Thomas Witkowski Thomas.Witkowski at tu-dresden.de
Tue Dec 20 13:58:18 CST 2011
Can any of you give me some advise, e.g. some link to literature, how
to solve indefinite systems with iterative solvers in an efficient
way? I have to solve systems coming from FEM discretization of a
6th-order time dependent PDE on structured grids. The time is
discretized with a standard backward euler scheme that introduces the
current timestep in one of the submatrices. This leads to some
problems. When the timestep is "small", the overall system has only
positive (but complex) eigenvalues. Using an apropriate krylov method
this can be solved within a reasonable number of iterations. When the
timestep is increased, the smallest eigenvalues become negative and
much larger in their magnitude. The number of iterations required for
solving this systems rise dramatically. It may be possible to increase
the timestep by just 1%, but the number of iterations of solving the
system rise up to three order of magnitude. Does any of you know some
methods/literature which can be used to deal with such systems?
If it is of interest, the overall system looks like:
A  0  I
0  A  tI
fI+2A  I  A
A is the discretization of the Laplace operator, I the identity
operator, t is the timestep and f: R^n -> R is some function defined
on the domain.
Thanks for any hint,
Thomas
