[petsc-users] Vec entries altered incorrectly
Juha Jäykkä juhaj at iki.fi
Mon Dec 19 13:18:03 CST 2011
> I guarantee you this is not a bug. This stuff is used by thousands of
> people every day.
That's what I thought, too.
> Its very simple and old code. There is a misunderstanding somewhere in your
> code about how this mechanism works. I suggest stripping down the code until
> there are just two vectors and you alter one.
Stripping it down will take a while, it is a relatively long piece, but I did
notice something that strikes me as odd:
What is the correct Fields.hdr.state at the point before calling
DAGlobalToLocalBegin()? My two vectors have a different value there and I
suspect that might be the reason. (The other vec has state 4, the other has
If that is so, how can that happen? I have checked quite a few times that all
DAGlobalToLocalBegin's have the corresponding End-call, that I pair every
DAVecGetArray with DAVecRestoreArray, and every DAGetLocalVector with
DARestoreLocalVector. Does the order in which I process the vectors matter
here? The order of DAGetLocalVector, DAGlobalToLocalBegin/End, and
DAVecGetArray for each vector obviously matters.
Cheers,
Juha
		| Juha Jäykkä, juhaj at iki.fi			|
		| http://www.maths.leeds.ac.uk/~juhaj		|
Name: not available
Desc: This is a digitally signed message part.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111219/c9e44e31/attachment.pgp>
