[petsc-users] Error in Petsc configuration
behzad baghapour
behzad.baghapour at gmail.com
Sun Dec 18 02:40:23 CST 2011
On Sat, Dec 17, 2011 at 5:43 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Are you sure these packages are installed at these locations? Did you
> install them manually?
Note: If this is a location from previous --dowload-mpich
> --download-hypre --download-parms builds - then these dirs just have
> sources - and not installs. One should continue to use the --download
> option [even though the sources are already downloaded]
> Yes. I exactly configured first with --download-XXX. Then How I should
configure if the next configurations will not need to download the packages
again?
Thank you very much.
> If you still have issues - correspond with petsc-maint with the
> appropriate configure.log
> Satish
> On Sat, 17 Dec 2011, behzad baghapour wrote:
> > Dear Developers,
> > I want to configure Petsc with given path for the external packages:
> > ./configure
> --with-f2cblaslapack-dir=/home/behzad/softs/petsc/externalpackages/f2cblaslapack-3.1.1.q
> > --with-mpi-dir=/home/behzad/softs/petsc/externalpackages/mpich2-1.4.1p1
> > --with-hypre-dir=/home/behzad/softs/petsc/externalpackages/hypre-2.7.0b
> > --with-parms-dir=/home/behzad/softs/petsc/externalpackages/pARMS_3.2
> > --with-debugging=no --with-cxx=g++ -with-clanguage=cxx
> > but I received the error:
> > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> > details):
> did
> > not work
> > and the procedure was terminated. I know I may in wrong way, please show
> me
> > how should be the configuring in this matter??
> > Thanks a lot,
> > BehZad
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111218/fd506198/attachment-0001.htm>
