[petsc-users] Problems with configure
Modhurita Mitra
modhurita at gmail.com
Sat Dec 17 18:05:31 CST 2011
I am trying to install PETSc while downloading MPICH, but I am facing
problems running the configure script. Some errors from the configure.log
file are:
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
details):
Error running configure on MPICH: Could not execute "cd
/export/home/modhurit/soft/petsc-3.2-p5/externalpackages/mpich2-1.4.1p1 &&
./configure
--prefix=/export/home/modhurit/soft/petsc-3.2-p5/arch-linux2-c-debug
CC="gcc" CFLAGS=" -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -g3 " --disable-cxx --disable-fc F77="g77" FFLAGS="
-Wall -Wno-unused-variable -g " --with-device=ch3:sock --without-mpe
--with-pm=hydra --enable-g=meminit --enable-fast":
Configuring MPICH2 version 1.4.1p1 with
'--prefix=/export/home/modhurit/soft/petsc-3.2-p5/arch-linux2-c-debug'
'CC=gcc' 'CFLAGS= -Wall -Wwrite-strings -Wno-strict-aliasing
-Wno-unknown-pragmas -g3 ' '--disable-cxx' '--disable-fc' 'F77=g77'
'FFLAGS= -Wall -Wno-unused-variable -g ' '--with-device=ch3:sock'
'--without-mpe' '--with-pm=hydra' '--enable-g=meminit' '--enable-fast'
Running on system: Linux faraday 2.6.18-194.26.1.el5 #1 SMP Tue Nov 9
12:54:40 EST 2010 i686 i686 i386 GNU/Linux
/export/home/modhurit/soft/petsc-3.2-p5/externalpackages/mpich2-1.4.1p1/src/mpl/configure:
line 7850: /scr/faraday/modhurit/matlab/RM: is a directory
mkdir: cannot create directory `conftest': File exists
line 7877: cd: conftest: Not a directory
mkdir: cannot create directory `out': File exists
line 7913: /scr/faraday/modhurit/matlab/RM: is a directory
cat: confdefs.h: No such file or directory
configure: error: Version information not found. Configuration aborted.
configure: error: MPL configure failed
File
"/export/home/modhurit/soft/petsc-3.2-p5/config/BuildSystem/config/packages/MPI.py",
line 528, in InstallMPICH
raise RuntimeError('Error running configure on MPICH: '+str(e))
What might be going wrong?
Modhurita
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111217/eac258da/attachment.htm>
