[petsc-users] PetscPrintf
Xiangdong Liang
xdliang at gmail.com
Tue Dec 13 11:21:49 CST 2011
On Tue, Dec 13, 2011 at 11:24 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Dec 13, 2011 at 10:19 AM, Xiangdong Liang <xdliang at gmail.com> wrote:
>> On Tue, Dec 13, 2011 at 11:14 AM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > On Tue, Dec 13, 2011 at 10:13 AM, Xiangdong Liang <xdliang at gmail.com>
>> > wrote:
>> >> Hello everyone,
>> >> I am using PetscPrintf(PETSC_COMM_WORLD,.....) to print out some
>> >> information. When I run the program on multiple processors, some of
>> >> these calls are printed out multiple times, while other calls are
>> >> printed out once. Should it be printed only once if I use
>> >> PETSC_COMM_WORLD? Thanks.
>> > The print is executed only on rank 0 of the communicator provided.
>> I agree. This implies that the message can be printed out at most
>> once. Do you have any hints why I saw the message printed out multiple
>> times? Thanks.
> Maybe
> 1) You have a bug in your code
> 2) You ran with the wrong mpiexec, so it just ran 2 copies
You're right. I use the wrong mpiexec. When I compile petsc-dev, I use
download-mpich while the default mpiexec in our system is openmpi. If
I use $PETSC_DIR/bin/petscmpiexec, the problem is fixed. Thanks, Matt
and Satish.
Xiangdong
> Matt
>> Xiangdong
>> > Matt
>> >> Xiangdong
>> >> PS. I am using petsc-dev. My code works fine on real petsc-3.1-p8. I
>> >> just switched to complex petsc-dev and see this problem.
>> > What most experimenters take for granted before they begin their
>> > experiments
>> > is infinitely more interesting than any results to which their
>> > experiments
>> > lead.
>> > -- Norbert Wiener
> What most experimenters take for granted before they begin their experiments
> is infinitely more interesting than any results to which their experiments
> lead.
> -- Norbert Wiener
