[petsc-users] petsc-users Digest, Vol 36, Issue 46
Aron Ahmadia
aron.ahmadia at kaust.edu.sa
Tue Dec 13 08:59:12 CST 2011
Hi Thomas,
That wasn't quite Matt's question, since MPI_Init gets called regardless of
whether you use mpiexec. He wants to know if your code breaks if
MPI_Init() is called, in which case we can blame this on your MPI
implementation and not PETSc :)
-A
On Tue, Dec 13, 2011 at 5:55 PM, Thomas Leissing <thomas.leissing at cstb.fr>wrote:
> > This sounds like MPI rather than PETSc, since it plays with output. Are
> you
> > running with mpiexec?
> > Matt
> Yes I do. I have the same results with and without mpiexec.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111213/e91643b1/attachment.htm>
