[petsc-users] debugging with no X11 available
Mon Dec 12 07:15:28 CST 2011
On Mon, Dec 12, 2011 at 7:11 AM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> Thanks for your answers. Meanwhile I clarified the situation a bit:
> I can bring xterm up manually from the command line, but the job is
> run using a scheduler (slurm). It then gets executed on arbitrary
> nodes (some stripped down linux) which apparently can not make X11
> connections.
Sometimes you can set the env on the compute nodes, and get DISPLAY right.
> Of course, they have their own debugging environment, but I just do
> not want to learn it now. The admins are unable to help me more. I
They should definitely be fired.
> tried running the debugger explicitly:
> aprun -n 2 -N 1 -d 1 -cc cpu gdb Solver run.xml
> but so only one gdb instance is invoked in the terminal window, the
> other is in a parallel universe or something... Still any chance to
> get the second window somehow?
Why not run 2 procs locally, instead of through the scheduler?
  Matt
> Thanks
> Dominik
> On Mon, Dec 12, 2011 at 1:52 PM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>
> wrote:
> > Sorry, to expand my answer, "what Matt said".  You don't have the
> advantage
> > of using the functionality of -start_in_debugger if you cannot make X11
> > connections from the compute nodes, so you will need to rely on whatever
> > debugging facilities your systems team has set up, and break on
> PetscError
> > if you want to catch PETSc errors percolating up the stack.
> > A
> > On Mon, Dec 12, 2011 at 3:48 PM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa
> > wrote:
> >> Not on a BG/P you can't.
> >> A
> >> On Mon, Dec 12, 2011 at 3:46 PM, Matthew Knepley <knepley at gmail.com>
> >> wrote:
> >>> On Mon, Dec 12, 2011 at 2:48 AM, Dominik Szczerba <
> >>> wrote:
> >>>> Hi,
> >>>> I am debugging my code on a system that does not allow any X11
> >>>> connections, therefore the following does not work:
> >>>> mpiexec -n 2 solver run.xml -start_in_debugger -display :0.0
> >>>> Are there alternative ways of using a debugger circumventing X11
> >>>> connections?
> >>> No. You can usually set the DISPLAY correctly for the backend machine.
> >>> Consult the admin.
> >>>    Matt
> >>>> Thanks
> >>>> Dominik
> >>> What most experimenters take for granted before they begin their
> >>> experiments is infinitely more interesting than any results to which
> their
> >>> experiments lead.
> >>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111212/73b5879d/attachment.htm>
