[petsc-users] Metis building
Fri Dec 9 07:35:27 CST 2011
  PETSc users,
  Please do NOT send configure/make issues  to petsc-users, send them to petsc-maint at mcs.anl.gov and ALWAYS send configure.log and make.log with the message.
   Barry
On Dec 9, 2011, at 4:51 AM, Alexander Grayver wrote:
> Hello,
> It's pretty weird situation now. A couple of weeks ago I configured petsc-3.2-p5 successfully, today I decided to do it with new options and it didn't work, I tried to do it with old options just to check and got error:
> lib/petsc-3.2-p5> ./configure --with-petsc-arch=intel-complex-debug-f-ds --with-fortran-interfaces=1 --download-superlu_dist --download-mumps --download-parmetis --download-metis  --with-scalapack-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_scalapack_lp64.a --with-scalapack-include=/opt/intel/Compiler/11.1/072/mkl/include --with-blacs-lib=/opt/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_blacs_openmpi_lp64.a --with-blacs-include=/opt/intel/Compiler/11.1/072/mkl/include --with-mpi-dir=/opt/mpi/intel/openmpi-1.4.2 --with-scalar-type=complex --with-blas-lapack-dir=/opt/intel/Compiler/11.1/072/mkl/lib/em64t --with-precision=double --with-x=0
>             Configuring PETSc to compile on your system
> ===============================================================================                                ***** WARNING: CC found in enviornment variables - ignoring ******                                 ===============================================================================                          ===============================================================================                                ***** WARNING: CXX found in enviornment variables - ignoring ******                                ===============================================================================                          ===============================================================================                                ***** WARNING: FC found in enviornment variables - ignoring ******                                 ===============================================================================                          ===============================================================================                                ***** WARNING: F77 found in enviornment variables - ignoring ******                                ===============================================================================                          ===============================================================================                                ***** WARNING: F90 found in enviornment variables - ignoring ******                                ===============================================================================                          ===============================================================================                                Compiling & installing Metis; this may take several minutes                                        ===============================================================================        *******************************************************************************
>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> Error running make on Metis: Could not execute "cd /home/lib/petsc-3.2-p5/externalpackages/metis-4.0.3 && make clean && make library && make minstall && make clean":
> (cd Lib ; make clean )
> make[1]: Entering directory `/home/lib/petsc-3.2-p5/externalpackages/metis-4.0.3/Lib'
> rm -f *.o
> make[1]: Leaving directory `/home/lib/petsc-3.2-p5/externalpackages/metis-4.0.3/Lib'
> (cd Programs ; make clean )
> make[1]: Entering directory `/home/lib/petsc-3.2-p5/externalpackages/metis-4.0.3/Programs'
> rm -f *.o
> make[1]: Leaving directory `/home/lib/petsc-3.2-p5/externalpackages/metis-4.0.3/Programs'
> (cd Test ; make clean )
> make[1]: Entering directory `/home/lib/petsc-3.2-p5/externalpackages/metis-4.0.3/Test'
> rm -f *.o
> make[1]: Leaving directory `/home/lib/petsc-3.2-p5/externalpackages/metis-4.0.3/Test'
> make: *** No rule to make target `library'.  Stop.
> I looked into /home/lib/petsc-3.2-p5/externalpackages/metis-4.0.3/makefile:
> default:
>    (cd Lib ; make )
>    (cd Programs ; make )
>    (cd Test ; make )
> clean:
> realclean:
>    (cd Lib ; make realclean )
>    (cd Programs ; make realclean )
>    (cd Test ; make realclean )
> So there is no library.
> I have no idea what went wrong. Any suggestions would be appreciated.
> Thanks in advance.
> Regards,
> Alexander
