[petsc-users] MATBDIAG in > 3.1
Parker, Andrew (UK Filton)
Andrew.Parker2 at baesystems.com
Wed Dec 7 02:54:00 CST 2011
Legends, nice one!
Got to that point in the souce code yesterday, saw that 7 was missing
from the switch statement, and got worried.
Is there any symmetry between the code in block size 5->6->7->8? I've
asked that without looking, so could be stupid question. The reason I
ask is that if there is this is a classic use of something like
boost-preprocessor macros or a bit of templating, as in the compiler
would expand it all out given a pattern at compile time? Just
interest....
Cheers again,
Andy
-----Original Message-----
[mailto:petsc-users-bounces at mcs.anl.gov] On Behalf Of Satish Balay
Sent: 06 December 2011 19:31
To: PETSc users list
Subject: Re: [petsc-users] MATBDIAG in > 3.1
*** WARNING ***
This message has originated outside your organisation,
either from an external partner or the Global Internet.
Keep this in mind if you answer this message.
On Tue, 6 Dec 2011, Matthew Knepley wrote:
> On Tue, Dec 6, 2011 at 7:43 AM, Parker, Andrew (UK Filton) <
> Andrew.Parker2 at baesystems.com> wrote:
> > So having got petsc 3.2 install and all its deps, I now get
> > this....****
> > [0]PETSC ERROR: PCSetUp_PBJacobi() line 207 in
> > src/ksp/pc/impls/pbjacobi/pbjacobi.c not supported for block size
> > 7****
> > Any thoughts?
> Sorry about that. There was confusion on our end. I have added the
> code you need to 3.2. It will go out with the next patch release.
> Alternatively, you can retrieve the source tarball from the repository
> site or use the repository directly.
I'm attaching this change as a patchfile - which can be applied to the
current
petsc-3.2 sources you have.
cd petsc-3.2
patch -Np1 < bpjacobi.patch
Satish
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender.
You should not copy it or use it for any purpose nor disclose or
distribute its contents to any other person.
