[petsc-users] MATBDIAG in > 3.1
Matthew Knepley
knepley at gmail.com
Tue Dec 6 12:59:38 CST 2011
On Tue, Dec 6, 2011 at 7:43 AM, Parker, Andrew (UK Filton) <
Andrew.Parker2 at baesystems.com> wrote:
> Hi,****
> So having got petsc 3.2 install and all its deps, I now get this….****
> [0]PETSC ERROR: PCSetUp_PBJacobi() line 207 in
> src/ksp/pc/impls/pbjacobi/pbjacobi.c not supported for block size 7****
> Any thoughts?
Sorry about that. There was confusion on our end. I have added the code you
need to 3.2. It will
go out with the next patch release. Alternatively, you can retrieve the
source tarball from the
repository site or use the repository directly.
Matt
> Cheers,****
> Andy****
> *From:* petsc-users-bounces at mcs.anl.gov [mailto:
> petsc-users-bounces at mcs.anl.gov] *On Behalf Of *Jed Brown
> *Sent:* 02 December 2011 12:42
> *To:* PETSc users list
> *Subject:* Re: [petsc-users] MATBDIAG in > 3.1****
> *** WARNING ***
> This message has originated outside your organisation,
> either from an external partner or the Global Internet.
> Keep this in mind if you answer this message.****
> On Fri, Dec 2, 2011 at 06:40, Parker, Andrew (UK Filton) <
> Andrew.Parker2 at baesystems.com> wrote:****
> [0]PETSC ERROR: MatInvertBlockDiagonal_SeqBAIJ() line 129 in
> src/mat/impls/baij/seq/baij.c not supported for block size 7****
> This was fixed in petsc-3.2****
> This email and any attachments are confidential to the intended
> recipient and may also be privileged. If you are not the intended
> recipient please delete it from your system and notify the sender.
> You should not copy it or use it for any purpose nor disclose or
> distribute its contents to any other person.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111206/3dcd750f/attachment.htm>
