[petsc-users] MATBDIAG in > 3.1
Parker, Andrew (UK Filton) Andrew.Parker2 at baesystems.com
Thu Dec 1 04:28:48 CST 2011
I've been using PETSc for a conventional full parallel implicit solver,
currently in MPIBAIJ format.  However, I'd like to understand the
performance verse memory and speed trade-offs of just having a block
diagonal system.  In this case I do not scatter to the off diagonal
blocks.  Each block is 7x7 in size and fully dense.  In my view this
should be a point implicit solution of the system.  I am looking for the
best way to solve this in PETSc, clearly because of the lack of coupling
between neighbouring cells by only having a block diagonal it's actually
a 7x7 dense linear solve, but to test my theory at present I'd prefer to
just not scatter to off diagonals, and use:
MATBDIAG with my current ksp solver and take it from there.  BDIAG seems
to have been removed as off 3.0:
http://www.mcs.anl.gov/petsc/documentation/changes/300.html
Can anybody help me with this, your thoughts on the above and what I
should use to solve this reduced system would be appreciated??
Cheers,
Andy
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender.
You should not copy it or use it for any purpose nor disclose or
distribute its contents to any other person.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20111201/5506b483/attachment.htm>
