[petsc-users] about ksp
    Likun Tan
    likunt at andrew.cmu.edu
    Tue Aug 30 12:08:49 CDT 2011
Dear all,
I am using MatCreateSeqDense() to create the matrix A, if i set np=2, i
got the error 'Comm must be of size 1'. As you suggested, i should put the
same dense matrix on every process, but how should i do it?
And also, should the right hand side matrix B be partitioned by column?
Likun
On Mon, August 29, 2011 6:01 pm, Jed Brown wrote:
> On Mon, Aug 29, 2011 at 16:49, Likun Tan <likunt at andrew.cmu.edu> wrote:
>> It is 27*27 with 343 non-zeros, i use LU for all the linear equations.
> This is just too small and not sparse enough for sparse linear algebra to
>  pay off. Create the same serial dense matrix redundantly on every
> process, factor it, put all your right hand sides for that process in a
> matrix B, and call MatMatSolve().
