[petsc-users] Vecscatter question
Jed Brown
jedbrown at mcs.anl.gov
Mon Aug 29 20:36:41 CDT 2011
On Mon, Aug 29, 2011 at 20:32, Tabrez Ali <stali at geology.wisc.edu> wrote:
> If during Vecscatter (say from a global vector x to a local vector y) if
> 'is' and 'iy' are such that almost all values being scattered happen to be
> on the local proc then almost 0 or very little MPI calls would be made
> internally. Is this correct?
Very few values would be sent anywhere. The number of MPI calls depends on
the number of processes that need to receive values and the scatter method
(methods descriptions:
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/docs/manualpages/Vec/VecScatterCreate.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110829/54f8a5cf/attachment.htm>
