[petsc-users] Vecscatter question
Tabrez Ali stali at geology.wisc.edu
Mon Aug 29 20:32:18 CDT 2011
Hello
If during Vecscatter (say from a global vector x to a local vector y) if
'is' and 'iy' are such that almost all values being scattered happen to
be on the local proc then almost 0 or very little MPI calls would be
made internally. Is this correct?
Such a setup would not cause scalability problems except consuming some
local proc memory due to 'y', 'is' and 'iy' being larger than required.
Thanks in advance.
Tabrez
