[petsc-users] about ksp
    Jed Brown
    jedbrown at mcs.anl.gov
    Mon Aug 29 16:46:56 CDT 2011
On Mon, Aug 29, 2011 at 16:36, Likun Tan <likunt at andrew.cmu.edu> wrote:
> If i keep using the uncoupled small system and use ksp to solve the linear
> equations sequentially, there is nowhere i can take advantage of parallel
> computing.
How small are your systems? Maybe you should just create the same matrix on
every processor and do a direct solve with all the right hand sides.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110829/b89854da/attachment.htm>
