[petsc-users] question about DA
Jed Brown
jedbrown at mcs.anl.gov
Sat Aug 27 15:28:02 CDT 2011
On Sat, Aug 27, 2011 at 15:24, Likun Tan <likunt at andrew.cmu.edu> wrote:
> g(temp) could be sum of temp[num][j][i] where num from 1 to N, so the
> index k is specified.
It could be, but you still didn't explain how the indices i and j were made
available to g() or what that code looks like. That is almost certainly your
problem. You might want to try running with valgrind.
Also, this is totally the wrong memory layout for performance (you want to
sum over the last index, unfortunately this requires changing your
interpretation of the x,y,z directions).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110827/5d553be8/attachment.htm>
