[petsc-users] Problem with SNES
    Milan Mitrovic
    milan.v.mitrovic at gmail.com
    Sat Aug 27 12:22:23 CDT 2011
Testing hand-coded Jacobian, if the ratio is O(1.e-8), the hand-coded
Jacobian is probably correct.
Run with -snes_test_display to show difference of hand-coded and
finite difference Jacobian.
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Unknown type. Check for miss-spelling or missing
external package needed for type
 see http://www.mcs.anl.gov/petsc/petsc-as/documentation/installation.html#external!
[1]PETSC ERROR: Unknown Mat type given: same!
[1]PETSC ERROR:
[1]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17
13:37:48 CDT 2011
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR:
[1]PETSC ERROR: ./ppm_pf on a darwin10. named
milan-mitrovics-macbook-pro.local by milan Sat Aug 27 19:11:18 2011
[1]PETSC ERROR: Libraries linked from /Users/milan/Work/Library/petsc/lib
[1]PETSC ERROR: Configure run at Fri May  6 16:32:02 2011
[1]PETSC ERROR: Configure options --with-mpi=true
--with-mpi-dir=/Users/milan/Work/Library/openmpi.gcc/
--with-fortran=true --with-sundials=true
--with-sundials-dir=/Users/milan/Work/Library/sundials/
--prefix=/Users/milan/Work/Library/petsc
--------------------- Error Message ------------------------------------
[0]PETSC ERROR: [1]PETSC ERROR:
[1]PETSC ERROR: MatSetType() line 51 in src/mat/interface/matreg.c
[1]PETSC ERROR: MatConvert() line 3521 in src/mat/interface/matrix.c
[1]PETSC ERROR: SNESSolve_Test() line 47 in src/snes/impls/test/snestest.c
[1]PETSC ERROR: SNESSolve() line 2255 in src/snes/interface/snes.c
