[petsc-users] Petsc has generated inconsistent data!
Barry Smith
bsmith at mcs.anl.gov
Fri Aug 26 16:31:48 CDT 2011
First run with valgrind http://www.mcs.anl.gov/petsc/petsc-as/documentation/faq.html#valgrind to make sure it does not have some "code bug cause".
Do you get the same message on one process.
My previous message still holds, if it is not a "code bug" then bi-CG-stab is just breaking down on that matrix and preconditioner combination.
Barry
On Aug 26, 2011, at 4:27 PM, Dominik Szczerba wrote:
> Later in the message he only requested that I use "-ksp_norm_type
> unpreconditioned". So I did, and the error comes back, now fully
> documented below. As I wrote, it works fine with gmres, and the
> problem is very simple, diagonal dominant steady state diffusion.
> Any hints are highly appreciated.
> Dominik
> #PETSc Option Table entries:
> -ksp_converged_reason
> -ksp_converged_use_initial_residual_norm
> -ksp_monitor_true_residual
> -ksp_norm_type unpreconditioned
> -ksp_rtol 1e-3
> -ksp_type bcgs
> -ksp_view
> -log_summary
> -pc_type jacobi
> #End of PETSc Option Table entries
> 0 KSP preconditioned resid norm 1.166190378969e+01 true resid norm
> 1.166190378969e+01 ||Ae||/||Ax|| 1.000000000000e+00
> 1 KSP preconditioned resid norm 5.658835826231e-01 true resid norm
> 5.658835826231e-01 ||Ae||/||Ax|| 4.852411688762e-02
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data!
> [0]PETSC ERROR: Divide by zero!
> [0]PETSC ERROR:
> [2]PETSC ERROR: --------------------- Error Message
> [2]PETSC ERROR: Petsc has generated inconsistent data!
> [2]PETSC ERROR: Divide by zero!
> [2]PETSC ERROR:
> [2]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17
> 13:37:48 CDT 2011
> [2]PETSC ERROR: See docs/changes/index.html for recent updates.
> [2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [2]PETSC ERROR: See docs/index.html for manual pages.
> [2]PETSC ERROR:
> [2]PETSC ERROR: /home/dsz/build/framework-debug/trunk/bin/cd3t10mpi on
> a linux-gnu named tharsis by dsz Fri Aug 26 23:23:47 2011
> [2]PETSC ERROR: Libraries linked from
> /home/dsz/pack/petsc-3.1-p8/linux-gnu-c-debug/lib
> [2]PETSC ERROR: Configure run at Mon Jul 25 14:20:10 2011
> [2]PETSC ERROR: Configure options
> PETSC_DIR=/home/dsz/pack/petsc-3.1-p8 PETSC_ARCH=linux-gnu-c-debug
> --download-f-blas-lapack=CD3T10::SaveSolution()
> [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17
> 13:37:48 CDT 2011
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: /home/dsz/build/framework-debug/trunk/bin/cd3t10mpi on
> [0]PETSC ERROR: Libraries linked from
> [0]PETSC ERROR: Configure run at Mon Jul 25 14:20:10 2011
> [0]PETSC ERROR: Configure options
> --download-f-blas-lapack=1 --download-mpich=1 --download-hypre=1
> --with-parmetis=1 --download-parmetis=1 --with-x=0 --with-debugging=1
> [0]PETSC ERROR:
> [0]PETSC ERROR: KSPSolve_BCGS() line 75 in
> src/ksp/ksp/impls/bcgs/[1]PETSC ERROR: --------------------- Error
> Message ------------------------------------
> [1]PETSC ERROR: Petsc has generated inconsistent data!
> [1]PETSC ERROR: Divide by zero!
> [1]PETSC ERROR:
> [1]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17
> 13:37:48 CDT 2011
> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [1]PETSC ERROR: See docs/index.html for manual pages.
> [1]PETSC ERROR:
> [1]PETSC ERROR: /home/dsz/build/framework-debug/trunk/bin/cd3t10mpi on
> [1]PETSC ERROR: Libraries linked from
> [1]PETSC ERROR: Configure run at Mon Jul 25 14:20:10 2011
> [1]PETSC ERROR: Configure options
> [2]PETSC ERROR:
> [2]PETSC ERROR: KSPSolve_BCGS() line 75 in src/ksp/ksp/impls/bcgs/bcgs.c
> [2]PETSC ERROR: KSPSolve() line 396 in src/ksp/ksp/interface/itfunc.c
> [2]PETSC ERROR: User provided function() line 1215 in
> "unknowndirectory/"/home/dsz/src/framework/trunk/solve/PetscSolver.cxx
> [3]PETSC ERROR: --------------------- Error Message
> [3]PETSC ERROR: Petsc has generated inconsistent data!
> [3]PETSC ERROR: Divide by zero!
> [3]PETSC ERROR:
> [3]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17
> 13:37:48 CDT 2011
> [3]PETSC ERROR: See docs/changes/index.html for recent updates.
> [3]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [3]PETSC ERROR: See docs/index.html for manual pages.
> [3]PETSC ERROR:
> [3]PETSC ERROR: /home/dsz/build/framework-debug/trunk/bin/cd3t10mpi on
> [3]PETSC ERROR: Libraries linked from
> [3]PETSC ERROR: Configure run at Mon Jul 25 14:20:10 2011
> [3]PETSC ERROR: Configure options
> --download-f-blas-lapack=bcgs.c
> [0]PETSC ERROR: KSPSolve() line 396 in src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: User provided function() line 1215 in
> 1 --download-mpich=1 --download-hypre=1 --with-parmetis=1
> [1]PETSC ERROR:
> [1]PETSC ERROR: KSPSolve_BCGS() line 75 in src/ksp/ksp/impls/bcgs/bcgs.c
> [1]PETSC ERROR: KSPSolve() line 396 in src/ksp/ksp/interface/itfunc.c
> [1]PETSC ERROR: User provided function() line 1215 in
> [3]PETSC ERROR:
> [3]PETSC ERROR: KSPSolve_BCGS() line 75 in src/ksp/ksp/impls/bcgs/bcgs.c
> [3]PETSC ERROR: KSPSolve() line 396 in src/ksp/ksp/interface/itfunc.c
> [3]PETSC ERROR: User provided function() line 1215 in
> PetscSolver::Finalize()
> PetscSolver::FinalizePetsc()
> On Fri, Aug 26, 2011 at 11:17 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> Are you sure that is the entire error message. It should print the routine and the line number where this happens.
>> Likely it is at
>> do {
>> ierr = VecDot(R,RP,&rho);CHKERRQ(ierr); /* rho <- (r,rp) */
>> beta = (rho/rhoold) * (alpha/omegaold);
>> ierr = VecAXPBYPCZ(P,1.0,-omegaold*beta,beta,R,V);CHKERRQ(ierr); /* p <- r - omega * beta* v + beta * p */
>> ierr = KSP_PCApplyBAorAB(ksp,P,V,T);CHKERRQ(ierr); /* v <- K p */
>> ierr = VecDot(V,RP,&d1);CHKERRQ(ierr);
>> if (d1 == 0.0) SETERRQ(((PetscObject)ksp)->comm,PETSC_ERR_PLIB,"Divide by zero");
>> alpha = rho / d1; /* a <- rho / (v,rp) */
>> Which means bi-cg-stab has broken down. You'll need to consult references to Bi-CG-stab to see why this might happen (it can happen while GMRES is happy). It may be KSPBCGSL can proceed past this point with a problem values for
>> Options Database Keys:
>> + -ksp_bcgsl_ell <ell> Number of Krylov search directions
>> - -ksp_bcgsl_cxpol Use a convex function of the MR and OR polynomials after the BiCG step
>> - -ksp_bcgsl_xres <res> Threshold used to decide when to refresh computed residuals
>> but most likely the preconditioner or matrix is bogus in some way since I think Bi-CG-stab rarely breaks down in practice.
>> Barry
>> On Aug 26, 2011, at 4:05 PM, Dominik Szczerba wrote:
>>> When solving my linear system with -ksp_type bcgs I get:
>>> [1]PETSC ERROR: --------------------- Error Message
>>> [1]PETSC ERROR:
>>> 13:37:48 CDT 2011
>>> [1]PETSC ERROR: [3]PETSC ERROR: --------------------- Error Message
>>> -ksp_monitor
>>> -ksp_right_pc
>>> -ksp_rtol 1e-3
>>> -ksp_type bcgs
>>> -ksp_view
>>> -log_summary
>>> -pc_type jacobi
>>> When solving the same system with GMRES all works fine. This is a
>>> simple test diffusion problem. How can I find out what the problem is?
>>> Dominik
