[petsc-users] No change in a.out compilation size after using PETSc shared library
TAY wee-beng
zonexo at gmail.com
Fri Aug 26 08:12:32 CDT 2011
Hi Barry,
Sorry, I am a mistake in the compilation directory and now it's about
1mb instead of 12mb. So it should be correct now.
Yours sincerely,
TAY wee-beng
On 25/8/2011 4:14 PM, Barry Smith wrote:
> Send configure.log make.log and ls ${PETSC_ARCH/lib to petsc-maint at mcs.anl.gov
> Barry
> On Aug 25, 2011, at 9:04 AM, TAY wee-beng wrote:
>> Hi,
>> I managed to compile PETSc shared library.
>> However, when I compile my code, my a.out 's size is still around 12mb, which is similar to using PETSc static library.
>> I thought it will be a much smaller exe. Shouldn't it be?
>> Thank you!
>> Yours sincerely,
>> TAY wee-beng
