[petsc-users] Mesh partitioning and MPI calls
Tabrez Ali
stali at geology.wisc.edu
Thu Aug 25 16:57:08 CDT 2011
I see the same behavior even if I stop the code right after my stiffness
matrix is assembled.
The only MPI comm before that is an epart/npart integer array BCast
(from proc 0 after the partitioning routine is called).
Tabrez
On 08/25/2011 04:14 PM, Dominik Szczerba wrote:
> Your expectation seems correct.
> How do you organize your points/dofs? It is very important for communication.
> Can you inspect which MPI messages are counted? Communication during
> matrix assembly may work better, but somewhere else in your code you
> may still assume cell ordering, thus contributing to the bigger total
> communication cost.
> Dominik
> On Thu, Aug 25, 2011 at 11:15 PM, Tabrez Ali<stali at geology.wisc.edu> wrote:
>> Hello
>> I have an unstructured FE mesh which I am partitioning using Metis.
>> In the first case I only use the element partitioning info and discard the
>> nodal partitioning info i.e., the original ordering is same as petsc's
>> global ordering. In the second case I do use the nodal partitioning info and
>> nodes are distributed accordingly.
>> I would expect that in the 2nd scenario the total number of MPI messages (at
>> the end of the solve) would be lower than the 1st. However I see that
>> opposite is true. See the plot at http://stali.freeshell.org/mpi.png
>> The number on the y axis is the last column of the "MPI messages:" field
>> from the -log_summary output.
>> Any ideas as to why this is happening. Does relying on total number of MPI
>> messages as a performance measure even make sense. Please excuse my
>> ignorance on the subject.
>> Alternatively what is a good way to measure how good the Metis partitioning
>> is?
>> Thanks in advance
>> Tabrez
