[petsc-users] Mesh partitioning and MPI calls
Tabrez Ali stali at geology.wisc.edu
Thu Aug 25 16:15:17 CDT 2011
Hello
I have an unstructured FE mesh which I am partitioning using Metis.
In the first case I only use the element partitioning info and discard
the nodal partitioning info i.e., the original ordering is same as
petsc's global ordering. In the second case I do use the nodal
partitioning info and nodes are distributed accordingly.
I would expect that in the 2nd scenario the total number of MPI messages
(at the end of the solve) would be lower than the 1st. However I see
that opposite is true. See the plot at http://stali.freeshell.org/mpi.png
The number on the y axis is the last column of the "MPI messages:" field
from the -log_summary output.
Any ideas as to why this is happening. Does relying on total number of
MPI messages as a performance measure even make sense. Please excuse my
ignorance on the subject.
Alternatively what is a good way to measure how good the Metis
partitioning is?
Thanks in advance
Tabrez
