[petsc-users] Freeing Preconditioner Matrix Space (Again)
Barry Smith
bsmith at mcs.anl.gov
Thu Aug 25 13:58:11 CDT 2011
On the C side of anything called by Fortran you must declare it as PC *pc rather than pc and then get the PC inside for example
void pcasmfreespace_(PC *inpc)
PC pc = *inpc;
On Aug 25, 2011, at 1:29 PM, Gaetan Kenway wrote:
> Hello
> I've managed to get the c-function for freeing preconditioner memory written. The contents of my new 'pcasmfreespace.c' is below:
> #include <private/pcimpl.h> /*I "petscpc.h" I*/
> typedef struct {
> PetscInt n, n_local, n_local_true;
> PetscInt overlap; /* overlap requested by user */
> KSP *ksp; /* linear solvers for each block */
> VecScatter *restriction; /* mapping from global to subregion */
> VecScatter *localization; /* mapping from overlapping to non-overlapping subregion */
> VecScatter *prolongation; /* mapping from subregion to global */
> Vec *x,*y,*y_local; /* work vectors */
> IS *is; /* index set that defines each overlapping subdomain */
> IS *is_local; /* index set that defines each non-overlapping subdomain, may be NULL */
> Mat *mat,*pmat; /* mat is not currently used */
> PCASMType type; /* use reduced interpolation, restriction or both */
> PetscInt type_set; /* if user set this value (so won't change it for symmetric problems) */
> PetscInt same_local_solves; /* flag indicating whether all local solvers are same */
> PetscInt sort_indices; /* flag to sort subdomain indices */
> } PC_ASM;
> void pcasmfreespace_(PC pc)
> PC_ASM *osm = (PC_ASM*)pc->data;
> PetscErrorCode ierr;
> if (osm->pmat) {
> if (osm->n_local_true > 0) {
> ierr = MatDestroyMatrices(osm->n_local_true,&osm->pmat);CHKERRQ(ierr);
> osm->pmat = 0;
> if (pc->pmat) {ierr = MatDestroy(pc->pmat);CHKERRQ(ierr); pc->pmat = 0;}
> Note the underscore as I'm trying to call it from Fortran. When I call it from fortran, I use:
> call pcasmfreespace(global_pc)
> This calls, the function, ok, but (according to Valgrind) I have an invalid read on the line containing:
> if (osm->pmat){
> I suspect this is something to do with passing the fortran "pointer" of the PC to c, or something along this lines. Is there anything else special you have to do to pass the "fortran" petsc objects to c?
> Thanks
> Gaetan
> Message: 2
> Date: Sun, 21 Aug 2011 17:22:28 -0500
> From: Barry Smith <bsmith at mcs.anl.gov>
> Subject: Re: [petsc-users] Freeing Preconditioner Matrix Space
> To: PETSc users list <petsc-users at mcs.anl.gov>
> Message-ID: <953121EF-B6AC-42EE-87BE-D4402C121652 at mcs.anl.gov>
> Content-Type: text/plain; charset=us-ascii
> You don't need to put that in the PETSc source. Just built it in the same directory you build your application and link it in like any of your application code. You will need to stick
> typedef struct {
> PetscBool type_set; /* if user set this value (so won't change it for symmetric problems) */
> PetscBool same_local_solves; /* flag indicating whether all local solvers are same */
> PetscBool sort_indices; /* flag to sort subdomain indices */
> } PC_ASM;
> before the subroutine.
> Barry
> On Aug 21, 2011, at 3:24 PM, Gaetan Kenway wrote:
> > Hello
> > I am attempting to implement a "hack" that was posted on the list a while back. I'm working with the adjoint linear system solver for a CFD solver. I'm using the ASM (or Block Jacobi) preconditioner with ILU(p) on each of the sub-domains. I use a different Preconditioner matrix (Pmat) than the actual jacobian. What I want to do is destroy the Pmat memory after the ILU factorization is performed. The hack that was posted is copied below:
> > PCASMFreeSpace(PC pc)
> > if (osm->pmat) {
> > osm->pmat = 0;
> > return 0;
> > However, I've had no luck actually getting the function compiled into petsc. There are no erorrs reported with i type "make" in the asm directory, but when I try to use the function in my application it can't find the symbol while linking. Where does it go in the asm.c file? Does it use "static PetscErrorCode" or "PetscErrorCode PETSCKSP_DLLEXPORT"? Does it have to be added to the .h include files? What has to be done for it work with Fortran?
> > Any suggestions would be greatly appreciated. This represents a significant chunk of my application's memory (10%-30%) and as such its too much to ignore. Also is there any chance something like this would make it into an actual PETSc release?
> > Gaetan
