[petsc-users] MPI_Scan under Fortran
Wienand Drenth w.drenth at gmail.com
Thu Aug 25 03:33:58 CDT 2011
Satish, Jed,
Thank you for the replies and suggestions for a solution.
The MPI_INTEGER4 seems to work. However, the MPIU_INTEGER suggested by
Satish gives the same error as did the MPIU_INT, though I include the
petscsys.h. Could it relate to the Petsc version? For compatibility reasons
I am using the 2.3.3 distribution.
regards,
Wienand
On Wed, Aug 24, 2011 at 10:20 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 24 Aug 2011, Jed Brown wrote:
> > On Wed, Aug 24, 2011 at 09:33, Wienand Drenth <w.drenth at gmail.com>
> wrote:
> > > The program compiles without troubles, but running it gives me an
> error. It
> > > is, I think, related to the MPI_SUM operation:
> > > [walrus:463] *** An error occurred in MPI_Scan: the reduction operation
> > > MPI_SUM is not defined on the MPI_BYTE datatype
> > > [walrus:463] *** on communicator MPI_COMM_WORLD
> > > [walrus:463] *** MPI_ERR_OP: invalid reduce operation
> > > [walrus:463] *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort)
> > > In addition, I needed to declare MPIU_INT explicitly as integer; this
> was
> > > not required for the C program.
> > I believe MPIU_INT (which is normally made to match PetscInt) is not
> defined
> > in Fortran. You can use MPI_INTEGER4 or MPI_INTEGER8 as needed.
> > Perhaps PETSc should define MPIU_INT, MPIU_SCALAR, etc in Fortran too?
> MPI does MPI_INT (c) vs MPI_INTEGER (fortran) - so we have
> MPIU_INTEGER on the fortran side. [in finclude/petscsys.h]
> And we do have MPIU_SCALAR on the fortran side.
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110825/da3f46d3/attachment.htm>
