[petsc-users] MPI_Scan under Fortran
Wed Aug 24 09:41:18 CDT 2011
On Wed, Aug 24, 2011 at 09:33, Wienand Drenth <w.drenth at gmail.com> wrote:
> The program compiles without troubles, but running it gives me an error. It
> is, I think, related to the MPI_SUM operation:
> [walrus:463] *** An error occurred in MPI_Scan: the reduction operation
> MPI_SUM is not defined on the MPI_BYTE datatype
> [walrus:463] *** on communicator MPI_COMM_WORLD
> [walrus:463] *** MPI_ERR_OP: invalid reduce operation
> [walrus:463] *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort)
> In addition, I needed to declare MPIU_INT explicitly as integer; this was
> not required for the C program.
I believe MPIU_INT (which is normally made to match PetscInt) is not defined
in Fortran. You can use MPI_INTEGER4 or MPI_INTEGER8 as needed.
Perhaps PETSc should define MPIU_INT, MPIU_SCALAR, etc in Fortran too?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110824/3edad063/attachment.htm>
