[petsc-users] debugger fails
Dominik Szczerba
dominik at itis.ethz.ch
Fri Aug 19 12:22:51 CDT 2011
What do you mean by "the second break"?
Dominik
On Fri, Aug 19, 2011 at 6:47 PM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa> wrote:
> You want to do a 'where' on the second break, when your program is raising
> an abort signal...
> A
> On Fri, Aug 19, 2011 at 6:57 PM, Dominik Szczerba <dominik at itis.ethz.ch>
> wrote:
>> (gdb) where
>> #0 0x00007fae5b941590 in __nanosleep_nocancel () at
>> ../sysdeps/unix/syscall-template.S:82
>> #1 0x00007fae5b94143c in __sleep (seconds=0) at
>> ../sysdeps/unix/sysv/linux/sleep.c:138
>> #2 0x000000000056cc48 in PetscSleep (s=10) at psleep.c:56
>> #3 0x0000000000838887 in PetscAttachDebugger () at adebug.c:410
>> #4 0x00000000005590a7 in PetscOptionsCheckInitial_Private () at
>> init.c:392
>> #5 0x000000000055e40e in PetscInitialize (argc=0x7ffff403debc,
>> args=0x7ffff403deb0, file=0x0,
>> help=0x0) at pinit.c:639
>> #6 0x0000000000524a16 in PetscSolver::InitializePetsc
>> (argc=0x7ffff403debc, argv=0x7ffff403deb0)
>> at /home/dsz/src/framework/trunk/solve/PetscSolver.cxx:124
>> #7 0x00000000004c404f in main (argc=4, argv=0x7ffff403e4c8)
>> at /home/dsz/src/framework/trunk/solve/cd3t10mpi_main.cxx:526
>> (gdb)
>> PetscSolver.cxx:124:
>> ierr = PetscInitialize(argc, argv, (char *)0, (char *)0);
>> CHKERRQ(ierr);
>> Hmmm, not very helpful.....
>> The app runs on one cpu, but silently crashes on two.
>> Any hints are very appreciated.
>> Dominik
>> On Fri, Aug 19, 2011 at 5:49 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> > On Fri, 19 Aug 2011, Dominik Szczerba wrote:
>> >> Hi,
>> >> I am starting my app in the debugger as:
>> >> mpiexec -np 2 sm3t4mpi run.xml -start_in_debugger -display :0.0
>> >> In the console I get:
>> >> [1]PETSC ERROR: MPI error 14
>> >> in the two open terminals with gdb I get:
>> >> 0x00007f2ecdd15590 in __nanosleep_nocancel () at
>> >> 82 ../sysdeps/unix/syscall-template.S: No such file or directory.
>> >> in ../sysdeps/unix/syscall-template.S
>> >> (gdb)
>> >> I type 'c' nonetheless and see:
>> >> (gdb) c
>> >> Continuing.
>> >> [New Thread 0x7f268e975700 (LWP 22388)]
>> >> Program received signal SIGABRT, Aborted.
>> >> 0x00007f268f421d05 in raise (sig=6) at
>> >> ../nptl/sysdeps/unix/sysv/linux/raise.c:64
>> >> 64 ../nptl/sysdeps/unix/sysv/linux/raise.c: No such file or
>> >> directory.
>> >> in ../nptl/sysdeps/unix/sysv/linux/raise.c
>> >> How do I go on debugging?
>> > what do you get for:
>> > (gdb) where
>> > Satish
>> >> Many thanks for any hints,
>> >> Dominik
