[petsc-users] debugger fails
    Dominik Szczerba
    dominik at itis.ethz.ch
    Fri Aug 19 10:27:05 CDT 2011
I am starting my app in the debugger as:
mpiexec -np 2 sm3t4mpi run.xml -start_in_debugger -display :0.0
In the console I get:
[1]PETSC ERROR: MPI error 14
in the two open terminals with gdb I get:
0x00007f2ecdd15590 in __nanosleep_nocancel () at
../sysdeps/unix/syscall-template.S:82
82      ../sysdeps/unix/syscall-template.S: No such file or directory.
        in ../sysdeps/unix/syscall-template.S
(gdb)
I type 'c' nonetheless and see:
(gdb) c
Continuing.
[New Thread 0x7f268e975700 (LWP 22388)]
Program received signal SIGABRT, Aborted.
0x00007f268f421d05 in raise (sig=6) at
../nptl/sysdeps/unix/sysv/linux/raise.c:64
64      ../nptl/sysdeps/unix/sysv/linux/raise.c: No such file or directory.
        in ../nptl/sysdeps/unix/sysv/linux/raise.c
How do I go on debugging?
Many thanks for any hints,
Dominik
