[petsc-users] Ordering of preallocation and OwnershipRange
Matthew Knepley
knepley at gmail.com
Sat Aug 13 10:28:41 CDT 2011
On Sat, Aug 13, 2011 at 2:57 PM, Josh Hykes <jmhykes at ncsu.edu> wrote:
> Hello,
> I'm just starting to experiment with PETSc (v3.1), and I like the Python
> bindings provided by petsc4py (v1.1.2). So far things seem fairly
> straightforward, but I'm stumped on a small issue.
> While creating a parallel AIJ matrix, I'd like to preallocate it using
> arrays d_nnz and o_nnz. As I understand it, these arrays correspond to the
> processor's local rows.
> Currently I specify the global matrix size, and let PETSc decide on the
> decomposition of the rows. I'd like to ask PETSc what rows each processor
> has with the getOwnershipRange() function, and then do the preallocation.
> However, according to the error message
> > [1] MatAnyAIJSetPreallocation() line 393 in
> petsc4py-1.1.2/src/include/custom.h
> > [1] Operation done in wrong order
> > [1] matrix is already preallocated
> I'm not allowed to do it in this order.
> Thus, my question is: is it possible to let PETSc figure out the row
> decomposition while still using d_nnz and o_nnz for the preallocation? I
> figure that I could resolve the problem by doing my own decomposition, but
> it'd be nice if I could let those details up to PETSc.
You are correct. We require that preallocation is done at the same time as
decomposition. There
are tricky dependencies in matrix creation. However, an easy workaround is
to create a Vec at
the same time with the same global size, since it is guaranteed to have the
same layout. I will look
into simplifying this if it is possible.
Matt
> I'm including an example using petsc4py of what I'd like to do, run with 2
> MPI processes.
> I apologize if this is a dumb question. Thank you for your help.
> -Josh
> from petsc4py import PETSc as petsc
> M, N = 4, 6
> global_d_nnz = [2, 1, 1, 2]
> global_o_nnz = [1, 3, 2, 1]
> A = petsc.Mat()
> A.create(petsc.COMM_WORLD)
> A.setSizes([M, N])
> A.setType('aij')
> i_start, i_end = A.getOwnershipRange()
> A.setPreallocationNNZ([global_d_nnz[i_start:i_end],
> global_o_nnz[i_start:i_end]]) # error occurs here
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110813/50716e6c/attachment.htm>
