[petsc-users] Problem With MatRestoreRow
Thu Aug 11 11:41:26 CDT 2011
  One problem is you cannot pass petsc_null in Fortran you must pass the specific type for example petsc_null_double or petsc_null_integer depending on the argument type.
This may or may not completely resolve the problem, send email to petsc-maint at mcs.anl.gov if you still have difficulties
    Barry
On Aug 11, 2011, at 11:00 AM, ked1 at rice.edu wrote:
> I am attempting to build a matrix and then get a row (or the number of nonzeros in the row) in Fortran 90. I can build the matrix and use it for calculations such as matrix multiplication, but if I call MatGetRow and then MatRestoreRow, I get an error about object type.
> However, if I reduce the size of the arrays I'm using in the MatSetValues command, everything works (except that I'm not building what I want).
> The section of my code giving trouble is below.
> ---------------------- CODE  BEGINS ----------------------------
> Mat  M
> PetscInt  dnnz(locneq), onnz(locneq), rows(64)
> PetscScalar Me(64*64)
> dnnz = 64
> onnz = 0
> call MatCreateMPIAIJ(petsc_comm_world,locneq,locneq,gnngu,gnngu,petsc_null,dnnz,petsc_null,onnz,M,ierr)
> Me = 1.0D0
> if (procid==0) then
>  do ii=1,ne        ! for all elements
>    do jj=1,64      ! for number of rows
>      kk = uconn(ii,jj)  ! get local node number
>      rows(jj) = gnoden(kk)-1  ! get global node number
>    end do
>    call MatSetValues(M,64,rows,64,rows,Me,add_values,ierr)
>  end do
> end if
> ! Assemble
> call MatAssemblyBegin(M,mat_final_assembly,ierr)
> call MatAssemblyEnd(M,mat_final_assembly,ierr)
> ! Get number of nonzero columns
> if (procid==0) then
>  call MatGetRow(M,0,ii,petsc_null,petsc_null,ierr)
>  print *, ii
>  call MatRestoreRow(M,0,ii,petsc_null,petsc_null,ierr)
> end if
> ---------------------- CODE  ENDS ----------------------------
> The error I get is
> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> [0]PETSC ERROR: Invalid argument!
> [0]PETSC ERROR: Wrong type of object: Parameter # 1!
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17 13:37:48 CDT 2011
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: ./semg3par on a linux-gnu named login1.sugar.rice.edu by ked1 Thu Aug 11 10:52:46 2011
> [0]PETSC ERROR: Libraries linked from /projects/bch3862/petsc/linux-gnu-c-debug/lib
> [0]PETSC ERROR: Configure run at Sun Jul 17 15:34:01 2011
> [0]PETSC ERROR: Configure options --with-cc=icc --with-fc=ifort --download-f-blas-lapack=1 --download-mpich=1
> [0]PETSC ERROR: MatRestoreRow() line 388 in src/mat/interface/matrix.c
> Line 388 in matrix.c is
> PetscValidHeaderSpecific(mat,MAT_COOKIE,1);
> Again, if I lower the number of rows, it will not give an error. In this case, replacing all instances of 64 with 46 will give no error. Going to 47 gives a error.
> Thanks for any help.
> Kenny
