[petsc-users] PETSC ERROR: Caught signal number 15 Terminate
Matthew Knepley
knepley at gmail.com
Tue Aug 9 22:42:34 CDT 2011
On Tue, Aug 9, 2011 at 10:36 PM, Debao Shao <Debao.Shao at brion.com> wrote:
> Hi, Matt: ****
> http://www.mcs.anl.gov/petsc/petsc-as/miscellaneous/petscthreads.html says
> “PETSc is not currently thread-safe”.****
> And, you said “PETSc allows threads”, I was confused, can you explain a
> little for me?
You are not prevented from using threads, but PETSc data structures are not
thread-safe (we do nothing
with threads). By allow, I meant you can do whatever you want, but we do not
supported a threaded model.
Sorry it was not clear.
Matt
> Thanks a lot. ****
> Debao ****
> *From:* petsc-users-bounces at mcs.anl.gov [mailto:
> petsc-users-bounces at mcs.anl.gov] *On Behalf Of *Matthew Knepley
> *Sent:* Saturday, August 06, 2011 11:19 AM
> *To:* PETSc users list
> *Subject:* Re: [petsc-users] PETSC ERROR: Caught signal number 15
> Terminate
> On Sat, Aug 6, 2011 at 1:34 AM, Debao Shao <Debao.Shao at brion.com> wrote:**
> Thanks a lot, Jed and Aron. ****
> Do you have ideas for this problem?****
> But I encounter a new problem, the situation is:****
> 1, the matrix is big, and can be partitioned to several blocks;****
> 2, started several threads to handle each block of matrix;****
> 3, integrated all block matrices together.****
> Again, the program crashed with reporting: ****
> "[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range"****
> Yes, PETSc allows threads, but one of your threads is illegally accessing
> memory. I suggest using valgrind to track this down.****
> Matt****
> My libpetsc.a is built with option "--with-mpi=0 --with-debugging=0
> -with-log=0 -with-info=0".****
> Will it support this type of multiple threads?****
> Thanks,****
> Debao****
> petsc-users-bounces at mcs.anl.gov] *On Behalf Of *Jed Brown
> *Sent:* Friday, August 05, 2011 9:26 PM
> Terminate****
> On Fri, Aug 5, 2011 at 04:00, Debao Shao <Debao.Shao at brion.com> wrote:****
> 1, I put "PetscInitialize" at the beginning of main, and "PetscInitialize"
> registers a signal handler to capture "SIGTERM";****
> 2, the problem ran in server side will send SIGTERM to kill all of clients
> after one stage is done.****
> 3, then, unfortunately, the signal "SIGTERM" is caught by the signal
> handler installed by "PetscInitialize", and caused to abort.****
> You can remove the order dependence by running with -no_signal_handler or
> setting your own signal handler with:****
> http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-dev/docs/manualpages/Sys/PetscPushSignalHandler.html
> -- The information contained in this communication and any attachments is
> confidential and may be privileged, and is for the sole use of the intended
> recipient(s). Any unauthorized review, use, disclosure or distribution is
> prohibited. Unless explicitly stated otherwise in the body of this
> communication or the attachment thereto (if any), the information is
> provided on an AS-IS basis without any express or implied warranties or
> liabilities. To the extent you are relying on this information, you are
> doing so at your own risk. If you are not the intended recipient, please
> notify the sender immediately by replying to this message and destroy all
> copies of this message and any attachments. ASML is neither liable for the
> proper and complete transmission of the information contained in this
> communication, nor for any delay in its receipt.****
> experiments lead.
> -- Norbert Wiener****
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110809/a6c6a2e6/attachment-0001.htm>
