[petsc-users] PETSC ERROR: PetscFinalize() line 968 in	src/sys/objects/pinit.c
    Aron Ahmadia
    aron.ahmadia at kaust.edu.sa
    Tue Aug  9 03:38:50 CDT 2011
Debao,
What is the complete traceback for this problem?
A
On Tue, Aug 9, 2011 at 11:12 AM, Debao Shao <Debao.Shao at brion.com> wrote:
>  DA, ****
> Do you happen to know what may cause this error?****
>          “[0]PETSC ERROR: PetscFinalize() line 968 in
> src/sys/objects/pinit.c”****
> After reporting this error, the job can run continued, but it will aborted
> when encountering next petsc related features even with calling
> PetscInitialize() again, and say:****
>          “Options have not been enabled.****
>          You might have forgotten to call PetscInitialize().”****
> Here is line 968:****
>          ierr = MPI_Finalize();CHKERRQ(ierr);****
> Thanks,****
> Debao****
> -- The information contained in this communication and any attachments is
> confidential and may be privileged, and is for the sole use of the intended
> recipient(s). Any unauthorized review, use, disclosure or distribution is
> prohibited. Unless explicitly stated otherwise in the body of this
> communication or the attachment thereto (if any), the information is
> provided on an AS-IS basis without any express or implied warranties or
> liabilities. To the extent you are relying on this information, you are
> doing so at your own risk. If you are not the intended recipient, please
> notify the sender immediately by replying to this message and destroy all
> copies of this message and any attachments. ASML is neither liable for the
> proper and complete transmission of the information contained in this
> communication, nor for any delay in its receipt.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110809/f1acb049/attachment-0001.htm>
