[petsc-users] SLEPc eigensolver that uses minimal memory and finds ALL eigenvalues of a real symmetric sparse matrix in reasonable time
    Jed Brown
    jedbrown at mcs.anl.gov
    Mon Aug  8 00:35:51 CDT 2011
On Mon, Aug 8, 2011 at 00:29, Shitij Bhargava <shitij.cse at gmail.com> wrote:
> I* *ran it with:
> mpirun -np 2 ./slepcEigenMPI -eps_monitor
> I didnt do exactly what you said, because the matrix generation part in the
> actual program is quite time consuming itself. But I assume what I am doing
> is equivalent to what you meant to do? Also, I put MPD as PETSC_DECIDE,
> because I didnt know what to put it for this matrix dimension.
> This is the output I get: (part of the output)
> *MATRIX ASSMEBLY DONE !!!!!!!!
>   1 EPS nconv=98 first unconverged value (error) 1490.88 (1.73958730e-05)
>   2 EPS nconv=282 first unconverged value (error) 3.04636e-27
> (2.49532175e-04)
> (2.49532175e-04)*
The most likely case is that you have more than one MPI implementation
installed and that you are running with a different implementation than you
built with. Compare the outputs:
$ ldd ./slepcEigenMPI
$ which mpirun
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110808/e56cd57c/attachment.htm>
