[petsc-users] Fatal error in MPI_Allreduce: Error message texts are not available[cli_9]: aborting job:
Sat Aug 6 01:02:13 CDT 2011
On Sat, Aug 6, 2011 at 5:58 AM, Dominik Szczerba <dominik at itis.ethz.ch>wrote:
> >> [9]PETSC ERROR: MPI error 14
> > This is the error for message truncation on receive. That usually means
> you
> > used the
> > wrong type in an MPI call.
> Thanks, that's already something to start with.
> > Also, run with -start_in_debugger and get a stack trace when it fails.
> >    Matt
> I get:
Your $DISPLAY is wrong.
   Matt
> [0]PETSC ERROR: PETSC: Attaching gdb to
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 12238 on
> display localhost:11.0 on machine nexo
> [1]PETSC ERROR: PETSC: Attaching gdb to
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 12239 on
> [2]PETSC ERROR: PETSC: Attaching gdb to
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 12240 on
> [3]PETSC ERROR: PETSC: Attaching gdb to
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 12241 on
> [4]PETSC ERROR: [5]PETSC ERROR: PETSC: Attaching gdb to
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 12243 on
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 12242 on
> [6]PETSC ERROR: PETSC: Attaching gdb to
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 12244 on
> [7]PETSC ERROR: [8]PETSC ERROR: PETSC: Attaching gdb to
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 12246 on
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 12245 on
> [11]PETSC ERROR: [10]PETSC ERROR: PETSC: Attaching gdb to
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 12249 on
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 12248 on
> [9]PETSC ERROR: PETSC: Attaching gdb to
> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 12247 on
> I am indeed remotely logged in, but can open terminal windows etc.
> Also -on_error_attach_debugger opens the gdb consoles properly.
> Thanks,
> Dominik
> >> [1]PETSC ERROR: MPI error 14
> >> [7]PETSC ERROR: MPI error 14
> >> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 11798 on
> >> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 11790 on
> >> [7]PETSC ERROR: PETSC: Attaching gdb to
> >> /home/dsz/build/framework-debug/trunk/bin/sm3t4mpi of pid 11796 on
> >> [9]PETSC ERROR: PetscGatherNumberOfMessages() line 62 in
> >> src/sys/utils/mpimesg.c
> >> [1]PETSC ERROR: PetscGatherNumberOfMessages() line 62 in
> >> [7]PETSC ERROR: PetscGatherNumberOfMessages() line 62 in
> >> When now starting the program in the 6 windows with its expected args
> >> results in:
> >> [cli_9]: PMIU_parse_keyvals: unexpected key delimiter at character 54 in
> >> cmd
> >> [cli_9]: parse_kevals failed -1
> >> I will not be able to do proper valgrinding/puryfying before next
> >> week. In the meantime I will still appreciate any hints.
> >> Regards,
> >> Dominik
> > What most experimenters take for granted before they begin their
> experiments
> > is infinitely more interesting than any results to which their
> experiments
> > lead.
> > -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110806/66416a79/attachment.htm>
