[petsc-users] Fatal error in MPI_Allreduce: Error message texts are not available[cli_9]: aborting job:
Fri Aug 5 21:12:57 CDT 2011
  Does the PETSc example src/vec/vec/examples/tutorials/ex1.c run correctly on 8+ processes?
  Are you sure the MPI shared libraries are the same on both systems?
   You can try the option -on_error_attach_debugger
  Barry
On Aug 5, 2011, at 4:41 PM, Dominik Szczerba wrote:
> I have a 2x6core. My solver works fine only on up to 8 processes,
> above that it always crashes with the below cited error. I did not yet
> valgrind etc. because I am in a desperate need to fix it quickly. I am
> just wondering what can potentially be the culprit.
> PS. I am not using MPI_Allreduce anywhere in my code.
> Many thanks for any hints,
> Dominik
> available[cli_1]: aborting job:
> available[cli_7]: aborting job:
> INTERNAL ERROR: Invalid error class (66) encountered while returning from
> MPI_Allreduce.  Please file a bug report.  No error stack is available.
> available[cli_11]: aborting job:
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 3 Quit: Some other process (or
> the batch system) has told this process to end
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSC
> ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
> find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: [0] MatAssemblyBegin_MPIAIJ line 462
> src/mat/impls/aij/mpi/mpiaij.c
> [0]PETSC ERROR: [0] MatAssemblyBegin line 4553 src/mat/interface/matrix.c
> [0]PETSC ERROR: [0] User provided functi[2]PETSC ERROR:
> [2]PETSC ERROR: Caught signal number 3 Quit: Some other process (or
> [2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [2]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[2]PETSC
> [2]PETSC ERROR: likely location of problem given in stack below
> [2]PETSC ERROR: ---------------------  Stack Frames
> [2]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [2]PETSC ERROR:       INSTEAD the line number of the start of the function
> [2]PETSC ERROR:       is given.
> [2]PETSC ERROR: [2] VecAssemblyBegin line 157 src/vec/vec/interface/vector.c
> [2]PETSC ERROR: [2] User provided function line 160
> "unknowndirectory/"/home/dsz/src/framework/trunk/solve/SM3T4mpi.cxx
> [INTERNAL ERROR: Invalid error class (66) encountered while returning from
> available[cli_3]: aborting job:
> [4]PETSC ERROR:
> [4]PETSC ERROR: Caught signal number 3 Quit: Some other process (or
> [4]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [4]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[4]PETSC
> [4]PETSC ERROR: likely location of problem given in stack below
> [4]PETSC ERROR: ---------------------  Stack Frames
> [4]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [4]PETSC ERROR:       INSTEAD the line number of the start of the function
> [4]PETSC ERROR:       is given.
> [4]PETSC ERROR: [4] MatAssemblyBegin_MPIAIJ line 462
> [4]PETSC ERROR: [4] MatAssemblyBegin line 4553 src/mat/interface/matrix.c
> [4]PETSC ERROR: [4] User provided functiINTERNAL ERROR: Invalid error
> available[cli_5]: aborting job:
> [6]PETSC ERROR:
> [6]PETSC ERROR: Caught signal number 3 Quit: Some other process (or
> [6]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [6]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[6]PETSC
> [6]PETSC ERROR: likely location of problem given in stack below
> [6]PETSC ERROR: ---------------------  Stack Frames
> [6]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [6]PETSC ERROR:       INSTEAD the line number of the start of the function
> [6]PETSC ERROR:       is given.
> [6]PETSC ERROR: [6] MatAssemblyBegin_MPIAIJ line 462
> [6]PETSC ERROR: [6] MatAssemblyBegin line 4553 src/mat/interface/matrix.c
> [6]PETSC ERROR: [6] User provided functiINTERNAL ERROR: Invalid error
> available[cli_8]: aborting job:
> [10]PETSC ERROR:
> [10]PETSC ERROR: Caught signal number 3 Quit: Some other process (or
> [10]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [10]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[10]PETSC
> [10]PETSC ERROR: likely location of problem given in stack below
> [10]PETSC ERROR: ---------------------  Stack Frames
> [10]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [10]PETSC ERROR:       INSTEAD the line number of the start of the function
> [10]PETSC ERROR:       is given.
> [10]PETSC ERROR: [10] VecAssemblyBegin line 157 src/vec/vec/interface/vector.c
> [10]PETSC ERROR: [10] User provided function line 160
> "unknowndirectory/"/home/dsz/src/framework/trunk/solve/on line 294
> [0]PETSC ERROR: [0] User provided function line 627
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17
> 13:37:48 CDT 2011
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: Unknown Name on a linux-gnu named nexo by dsz Sat Aug
> 6 00:35:58 2011
> [0]PETSC ERROR: Libraries linked from
> /home/dsz/pack/petsc-3.1-p8/linux-gnu-c-debug/lib
> [0]PETSC ERROR: Configure run at Sat Aug  6 00:02:58 2011
> [0]PETSC ERROR: Config2]PETSC ERROR: [2] User provided function line
> 294 "unknowndirectory/"/home/dsz/src/framework/trunk/solve/SM3T4mpi.cxx
> [2]PETSC ERROR: [2] User provided function line 627
> [2]PETSC ERROR: --------------------- Error Message
> [2]PETSC ERROR: Signal received!
> [2]PETSC ERROR:
> [2]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17
> 13:37:48 CDT 2011
> [2]PETSC ERROR: See docs/changes/index.html for recent updates.
> [2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [2]PETSC ERROR: See docs/index.html for manual pages.
> [2]PETSC ERROR:
> [2]PETSC ERROR: Unknown Name on a linux-gnu named nexo by dsz Sat Aug
> 6 00:35:58 2011
> [2]PETSC ERROR: Libraries linked from
> [2]PETSC ERROR: Configure run at Sat Aug on line 294
> [4]PETSC ERROR: [4] User provided function line 627
> [4]PETSC ERROR: --------------------- Error Message
> [4]PETSC ERROR: Signal received!
> [4]PETSC ERROR:
> [4]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17
> 13:37:48 CDT 2011
> [4]PETSC ERROR: See docs/changes/index.html for recent updates.
> [4]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [4]PETSC ERROR: See docs/index.html for manual pages.
> [4]PETSC ERROR:
> [4]PETSC ERROR: Unknown Name on a linux-gnu named nexo by dsz Sat Aug
> 6 00:35:58 2011
> [4]PETSC ERROR: Libraries linked from
> [4]PETSC ERROR: Configure run at Sat Aug  6 00:02:58 2011
> [4]PETSC ERROR: Configon line 294
> [6]PETSC ERROR: [6] User provided function line 627
> [6]PETSC ERROR: --------------------- Error Message
> [6]PETSC ERROR: Signal received!
> [6]PETSC ERROR:
> [6]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17
> 13:37:48 CDT 2011
> [6]PETSC ERROR: See docs/changes/index.html for recent updates.
> [6]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [6]PETSC ERROR: See docs/index.html for manual pages.
> [6]PETSC ERROR:
> [6]PETSC ERROR: Unknown Name on a linux-gnu named nexo by dsz Sat Aug
> 6 00:35:58 2011
> [6]PETSC ERROR: Libraries linked from
> [6]PETSC ERROR: Configure run at Sat Aug  6 00:02:58 2011
> [6]PETSC ERROR: ConfigSM3T4mpi.cxx
> [10]PETSC ERROR: [10] User provided function line 294
> [10]PETSC ERROR: [10] User provided function line 627
> [10]PETSC ERROR: --------------------- Error Message
> [10]PETSC ERROR: Signal received!
> [10]PETSC ERROR:
> [10]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17
> 13:37:48 CDT 2011
> [10]PETSC ERROR: See docs/changes/index.html for recent updates.
> [10]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [10]PETSC ERROR: See docs/index.html for manual pages.
> [10]PETSC ERROR:
> [10]PETSC ERROR: Unknown Name on a linux-gnu named nexo by dsz Sat Aug
> 6 00:35:58 2011
> [10]PETSC ERROR: Libraries linked from
> [10]PETSC ERRure options PETSC_DIR=/home/dsz/pack/petsc-3.1-p8
> PETSC_ARCH=linux-gnu-c-debug --download-f-blas-lapack=1
> --download-mpich=1 --download-hypre=1 --with-parmetis=1
> --download-parmetis=1 --with-x=0 --with-debugging=1
> [0]PETSC ERROR:
> [0]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0[cli_0]:
> aborting job:
> 6 00:02:58 2011
> [2]PETSC ERROR: Configure options
> PETSC_DIR=/home/dsz/pack/petsc-3.1-p8 PETSC_ARCH=linux-gnu-c-debug
> --download-f-blas-lapack=1 --download-mpich=1 --download-hypre=1
> --with-parmetis=1 --download-parmetis=1 --with-x=0 --with-debugging=1
> [2]PETSC ERROR:
> [2]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 2[cli_2]:
> aborting job:
> [4]PETSC ERROR:
> [4]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 4[cli_4]:
> aborting job:
> [6]PETSC ERROR:
> [6]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 6[cli_6]:
> aborting job:
> [10]PETSC ERROR: Configure options
> [10]PETSC ERROR:
> [10]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 10[cli_10]:
> aborting job:
