[petsc-users] Fatal error in MPI_Allreduce: Error message texts are not available[cli_9]: aborting job:
Fri Aug 5 18:02:13 CDT 2011
On Fri, Aug 5, 2011 at 16:58, Dominik Szczerba <dominik at itis.ethz.ch> wrote:
> Why would it happen only for np>8?
Depends on the logic in your code. I would start in a debugger with
breakpoints on the lines calling MatAssemblyBegin() and VecAssemblyBegin().
You can get line numbers from the stack trace you sent, if you are calling
those functions more than once.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110805/82273d1f/attachment.htm>
