[petsc-users] Fatal error in MPI_Allreduce: Error message texts are not available[cli_9]: aborting job:
Fri Aug 5 17:57:33 CDT 2011
On Fri, Aug 5, 2011 at 16:41, Dominik Szczerba <dominik at itis.ethz.ch> wrote:
> I did not yet
> valgrind etc. because I am in a desperate need to fix it quickly.
It's usually harder to fix the problem by guessing than it is if you use
tools designed to help you. In this case, I suspect that different processes
are calling VecAssemblyBegin() and MatAssemblyBegin() with different
arguments or in a different order.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110805/c76d90e7/attachment.htm>
