[petsc-users] PETSC ERROR: Caught signal number 15 Terminate
    Matthew Knepley
    knepley at gmail.com
    Thu Aug  4 21:43:35 CDT 2011
On Fri, Aug 5, 2011 at 2:38 AM, Debao Shao <Debao.Shao at brion.com> wrote:
> Doesn’t SEGV fault is signal 11?
Yes, 15 is SIGTERM. It appears that either you have another signal handler
installed which
is terminating on an error, or something killed your program. I can
guarantee you that the
PetscInitialize(0,0,0,0) is a seg fault.
   Matt
> *From:* petsc-users-bounces at mcs.anl.gov [mailto:
> petsc-users-bounces at mcs.anl.gov] *On Behalf Of *Matthew Knepley
> *Sent:* Friday, August 05, 2011 10:35 AM
> *To:* **PETSc users list**
> *Subject:* Re: [petsc-users] PETSC ERROR: Caught signal number 15
> Terminate
> On Fri, Aug 5, 2011 at 2:33 AM, **De**bao Shao <Debao.Shao at brion.com>
> wrote:****
>  So the real problem is the wrong usage of “PetscInitialize(0, 0, 0, 0 )”,
> but I do have many successive runs before with this setting.****
> Any kind of memory overwrite gives an SEGV. So other code, making a
> different error will give that too.****
>    Matt****
> Thanks,****
> **De**bao****
> *Sent:* Friday, August 05, 2011 10:25 AM
> Terminate****
> On Fri, Aug 5, 2011 at 2:20 AM, **De**bao Shao <Debao.Shao at brion.com>
> wrote:****
>   DA: ****
> Sometimes I may encounter crashing when using PETSc, it doesn’t happen
> always. ****
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the
> batch system) has told this process to end****
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/petsc-as/documentation/troubleshooting.html#Signal[0]PETSCERROR: or try
> http://valgrind.org on GNU/linux****
> and Apple Mac OS X to find memory corruption errors****
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
> run****
> [0]PETSC ERROR: to get more information on the crash.****
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received!****
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.1.0, Patch 8, Thu Mar 17 13:37:48
> CDT 2011****
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.****
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.****
> [0]PETSC ERROR: See docs/index.html for manual pages.****
> [0]PETSC ERROR:
> [0]PETSC ERROR: Unknown Name on a linux-gnu named r0leaf17 by tachyon Thu
> Aug  4 04:04:19 2011****
> [0]PETSC ERROR: Libraries linked from
> /home/dshao/dev_t2k/third_party/OOQP/OOQP-0.99.19/extras/petsc-3.1-p8/linux-gnu-c-debug/lib
> [0]PETSC ERROR: Configure run at Thu Apr 21 18:09:19 2011****
> [0]PETSC ERROR: Configure options --with-mpi=0 --with-debugging=0
> -with-log=0 -with-info=0****
> [0]PETSC ERROR:
> [0]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file****
> Do you happen to know the possible cause?****
> I also have a question about the usage of “PetscInitialize” &
> “PetscFinalize”. I can’t totally understand them from the manual. ****
> Now, I wrote it as: ****
> Int main(int argc, char **argv)****
>          PetscInitialize(0, 0, 0, 0 );****
> This is not a valid call. Try****
>   PetscInitialize(&argc, &argv, 0, 0);****
> Signal 15 is a segmentation fault, which means an illegal memory read or
> write.****
>    Matt****
>          VerifyApp app(argc, argv);****
>          app.Initialize();****
>          app.Run();****
>          PetscFinalize();****
>          return 0;****
> Then, built a binary, say “verify”, and executed “verify” on a server
> first, then, started another “verify” on client by server. ****
> The program ran at client side can be multiple processes and multiple
> threads.****
> Is my usage correct? ****
> Your answer is appreciated. ****
> Thanks,****
> **De**bao****
> -- The information contained in this communication and any attachments is
> confidential and may be privileged, and is for the sole use of the intended
> recipient(s). Any unauthorized review, use, disclosure or distribution is
> prohibited. Unless explicitly stated otherwise in the body of this
> communication or the attachment thereto (if any), the information is
> provided on an AS-IS basis without any express or implied warranties or
> liabilities. To the extent you are relying on this information, you are
> doing so at your own risk. If you are not the intended recipient, please
> notify the sender immediately by replying to this message and destroy all
> copies of this message and any attachments. ASML is neither liable for the
> proper and complete transmission of the information contained in this
> communication, nor for any delay in its receipt.****
> experiments lead.
> -- Norbert Wiener****
> experiments lead.
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110805/3dc18a15/attachment-0001.htm>
