[petsc-users] Metis partitioning question
    Mohammad Mirzadeh
    mirzadeh at gmail.com
    Thu Aug  4 19:52:47 CDT 2011
if you want to use a general unstructured grid, you may want to have a look
at $PETSC_DIR/src/dm/ao/examples/tutorials/ex2.c
Mohammad
On Thu, Aug 4, 2011 at 4:43 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Aug 4, 2011 at 11:31 PM, Tabrez Ali <stali at geology.wisc.edu>wrote:
>> Hello
>> If a mesh is partitioned using Metis but the original order of nodes is
>> used to create/partition the matrix then would this be significantly bad for
>> performance and scalability.
> That depends. Many mesh generators h ave fairly good ordering on output,
> but some do not. Definitely a bad order can make a huge
> difference in performance, both for cache traffic and conditioning reasons.
>> Also is there an example that uses Metis to partition an unstructured
>> mesh?
> This depends on what you mean. If you can encode your mesh as a Mat, you
> can use MatPartitoning. If not,
> you would need to use DMMesh things, such as SNES ex12.
>     Matt
>> Thanks in advance.
>> Tabrez
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110804/6483f6a7/attachment.htm>
