[petsc-users] SLEPc eigensolver that uses minimal memory and finds ALL eigenvalues of a real symmetric sparse matrix in reasonable time
Shitij Bhargava shitij.cse at gmail.com
Thu Aug 4 01:48:18 CDT 2011
Thank you very much for your reply.
I am a summer trainee, and I talked to my guide about this, and now what I
want might be a little different.
I really do want all the eigenvalues. There cannot be any compromise on
that. But please note that time is not much of a concern here, the much
bigger concern is of memory.  Even if I can distribute the memory somehow
for the computation of all eigenvalues, that is fine. (doesnt matter if it
takes a huge amount of time, he is willing to wait). Can any slepc
Eigensolver distribute memory this way while solving for all eigenvalues ?
I am sorry if what I am asking is obvious, I dont know much about
distributed memory, etc. also. I am stupid at this moment, but I am
learning.
Also, when I ran the slepc program on a small cluster, and then ran the top
command, I saw that while solving for eigenvalues, the program was already
using upto 500% CPU. Does this mean that the eigensolver was "distributing
memory" automatically among different nodes ? I understand that it must be
distributing computational effort, but how do I know if it was distributing
memory also ? It simply showed me the RES memory usage to be 1.3 gb, and the
%MEM to be about 17%. Also, I did not use any MPIXXX data structures. I
simply used SeqAIJ. Will using MPIAIJ "distribute memory" while solving for
all eigenvalues  ? (I understand that it will distribute memory to store the
matrix, but the memory bottleneck is eigenvalue solver, so its more
important for memory to be distributed then ) My guide said that one node
will not have enough memory, but all nodes combined will, and hence the
requirement of memory to be distributed.
I read about ScaLAPACK, and I have already asked on their forums to confirm
if it is suitable for me. I am waiting for an answer.
Thank you once again.
Shitij
On 3 August 2011 14:31, Jose E. Roman <jroman at dsic.upv.es> wrote:
> El 03/08/2011, a las 08:30, Shitij Bhargava escribió:
> > Hi all !!
> > The reason I have started using SLEPc/PETSc is that I want to reduce the
> memory requirements of a program that I already have in Intel MKL. The
> program's purpose is to calculate ALL eigenvalues and eigenvectors of a real
> symmetric sparse matrix. Intel MKL doesnt have a sparse solver for this
> (cant solve for eigenvalues of a matrix represented in sparse format), so I
> am using SLEPc, as it can do this.
> > (NOTE: by "sparsity" I mean ZEROES*100/(ZEROES+NONZEROES). Also the
> tolerance I am using is 10^-6)
> If you really want to compute ALL eigenvalues, then SLEPc is not the way to
> go. SLEPc is intended for computing a few eigenpairs, and in some cases a
> few percentage, e.g. 20% at most. Computing more than that with SLEPc is
> probably going to be less efficient than other alternatives.
> > Till now I have been using the LAPACK method (EPSLAPACK) for the slepc
> eigensolver, as I found out that it was the fastest (I configured PETSc to
> use Intel MKL BLAS/LAPACK routines). But I just found out that it is using a
> lot of memory irrespective of the sparsity of  the matrix. For example, on a
> matrix of order 9600x9600 no matter how sparse/dense it is (I tested from
> 0.02% to 75% sparsity), it used  1.3gb of peak memory every time, whereas
> the part of the program in which the matrix is assembled in AIJ format (in
> case of 75% sparsity) takes only 550mb. The MKL program takes 3.1gb.
> Although memory requirement is less, the difference is constant irrespective
> of sparsity.So, it seems that the LAPACK method will use memory dependent on
> the order of the matrix, irrespective of the sparsity. So I guess its not
> very suitable for my purpose ? I also tried changing the NCV and MPD
> (Maximum projected Dimension) parameters hoping they would somehow reduce
> memory requirements even if at the cost of more time, but whatever I pass
> NCV and MPD (in EPSSetDimensions) as, they are not considered at all. They
> remain the same as the default values (as I verified with EPSGetDimensions).
> The EPSLAPACK solver converts the matrix to dense format. As explained in
> the documentation, this solver must be used only on small matrices for
> debugging purposes. NCV and MPD are not relevant in this setting.
> > So I tried other solvers like the default, krylovschur, lanczos, but I
> think they are built to find only a few eigenvalues and not all, because
> they almost never converged to find ALL eigenvalues, even if I gave them a
> lot of time (big max number of iterations parameter). But their memory
> requirements seem to be pretty less. For example, I ran the program with
> EPSLANCZOS on the same 9600x9600 matrix (75% sparsity) with maximum number
> of iterations as 500,000. It ran it for 6.5 hrs (then I killed it), and at
> the end it was using 530mb only (although I dont know how near it was to
> completion).
> Krylov-Schur is almost always preferred over Lanczos, since the latter
> implements an explicit restart which is much worse than implicit restart in
> Krylov-Schur. Anyway, in both of them if you set NEV=9600 you are building a
> projected problem (dense matrix) of order equal to the original matrix so
> you have the same cost as with EPSLAPACK together with the cost of building
> the Krylov subspace. Again: do not use SLEPc for all eigenvalues!
> > I am somewhat illiterate about the mathematics behind all this, and how
> the lapack,krylovschur, etc. work and I have no idea if what I am
> experiencing was expected/obvious, although I half-expected some things by
> reading the slepc documentation, where a table was given comparing different
> eigensolvers.
> A general recommendation is to try to understand a little bit how the
> algorithms work before attempting to use them.
> > Also, I have observed that as the sparsity of the matrix increases (more
> zeroes), more eigenvalues also become zeroes. Is there a way to exploit this
> using probably krylovschur/lanczos so that there is no need to converge to
> all eigenvalues (meaning that the time they will take will be reasonable),
> but to only the number of eigenvalues that are non-zero,so that I can assume
> the non-converged eigenvalues to be simply zeroes (but is there a way to
> know beforehand by sparsity approximately how many non-zeroe eigenvalues
> will be there, and the corresponding value of maximum iterations that are
> required ?)
> There is no direct connection between the number of zero entries and the
> number of zero eigenvalues, unless you have rows/columns with all zeros, in
> which case the (permuted) matrix can be written as A=[A11 0; 0 0] so it is
> enough to compute eigenvalues of A11.
> > Is there a way to do what I want to do through SLEPc ???  I want ALL
> eigenvalues and want that the memory requirements of the eigensolver should
> be less/in accordance with the sparsity of the matrix, otherwise the very
> purpose of using a sparse matrix representation is somewhat defeated. I am
> doing all this in FORTRAN by the way.
> Ask yourself this question: is it really necessary to compute all
> eigenvalues? If the answer is yes then maybe ScaLAPACK is what you need.
> Jose
> > Thanks a lot in advance !!!
> > Shitij
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110804/c178ca4b/attachment.htm>
