[petsc-users] valgrind
Barry Smith
bsmith at mcs.anl.gov
Tue Aug 2 12:49:31 CDT 2011
On Aug 2, 2011, at 11:38 AM, Kuhlemann, Verena wrote:
> So, the first real error that I get is
> Invalid write of size 4
> ==24909== at 0x9B3B9F: Moc_ComputePartitionParams__ (kwayrefine.c:215)
> ==24909== by 0x9A1D28: Moc_Global_Partition__ (kmetis.c:231)
> ==24909== by 0x9A1D00: Moc_Global_Partition__ (kmetis.c:228)
> ==24909== by 0x9A1619: ParMETIS_V3_PartKway (kmetis.c:137)
> ==24909== by 0x557AC8: MatPartitioningApply_Parmetis (pmetis.c:97)
> ==24909== by 0x554058: MatPartitioningApply (partition.c:236)
> ==24909== by 0x404DE2: main (runtests.c:99)
> Any ideas why?
bug in kwayrefine.c at line 215
Have fun debugging parmetis :-(
Barry
> I will try to use --download-mpich for valgrind debugging./
> Thanks,
> Verena
> From: petsc-users-bounces at mcs.anl.gov [petsc-users-bounces at mcs.anl.gov] on behalf of Satish Balay [balay at mcs.anl.gov]
> Sent: Tuesday, August 02, 2011 1:35 PM
> To: PETSc users list
> Subject: Re: [petsc-users] valgrind
> Also suggest using --download-mpich - for valgrind debugging. [it gives
> you a valgrind clean mpich]
> Satish
> On Tue, 2 Aug 2011, Matthew Knepley wrote:
>> On Tue, Aug 2, 2011 at 5:06 PM, Kuhlemann, Verena <vkuhlem at emory.edu> wrote:
>>> Hi,
>>> I am trying to find an error in my program with valgrind.
>>> The first message that I get is the following:
>> No, MPICH is doing something that valgrind does not understand with memory.
>> You can usually
>> ignore anything that goes back into MPI.
>> Matt
>>> Syscall param write(buf) points to uninitialised byte(s)
>>> ==22395== Syscall param write(buf) points to uninitialised byte(s)
>>> ==22393== at 0x73D92C0: __write_nocancel (in /lib64/libc-2.5.so)
>>> ==22393== by 0x7A76283: ibv_cmd_modify_qp (in
>>> /usr/lib64/libibverbs.so.1.0.0)
>>> ==22393== by 0x88B742A: ??? (in /usr/lib64/libmlx4-rdmav2.so)
>>> ==22393== by 0x7A7A363: ibv_modify_qp (in
>>> ==22393== by 0x67A3DDF: MPID_VIA_Init (viainit.c:1014)
>>> ==22393== by 0x67826BB: MPID_Init (mpid_init.c:66)
>>> ==22393== by 0x677438E: MPIR_Init (initutil.c:279)
>>> ==22393== by 0x432732: PetscInitialize (pinit.c:561)
>>> ==22395== at 0x73D92C0: __write_nocancel (in /lib64/libc-2.5.so)
>>> ==22395== by 0x7A76283: ibv_cmd_modify_qp (in
>>> ==22395== by 0x88B742A: ??? (in /usr/lib64/libmlx4-rdmav2.so)
>>> ==22395== by 0x7A7A363: ibv_modify_qp (in
>>> ==22395== by 0x67A3DDF: MPID_VIA_Init (viainit.c:1014)
>>> ==22395== by 0x67826BB: MPID_Init (mpid_init.c:66)
>>> ==22395== by 0x677438E: MPIR_Init (initutil.c:279)
>>> ==22395== by 0x432732: PetscInitialize (pinit.c:561)
>>> ==22395== by 0x4046FC: main (runtests.c:48)
>>> ==22395== Address 0x7feffef78 is on thread 1's stack
>>> I am not sure what this is suppose to tell me. Is the something wrong
>>> with my PetscInitialize?
>>> Thanks for the help,
>>> Verena
>>> This e-mail message (including any attachments) is for the sole use of
>>> the intended recipient(s) and may contain confidential and privileged
>>> information. If the reader of this message is not the intended
>>> recipient, you are hereby notified that any dissemination, distribution
>>> or copying of this message (including any attachments) is strictly
>>> prohibited.
>>> If you have received this message in error, please contact
>>> the sender by reply e-mail message and destroy all copies of the
>>> original message (including attachments).
