[petsc-users] SLEPc generalized eigenvalue problem question?
    Aron Ahmadia
    aron.ahmadia at kaust.edu.sa
    Tue Aug  2 04:05:04 CDT 2011
> Found a PDF, "MATRICES IN PETSc", (after much googling) but not sure which
> of the many forms will work and which is best.
> ---John
As a general piece of advice, always consult the documentation provided by
the developers of a software package before typing search terms in Google.
 This is particularly harmful with PETSc, since there are about 10 years
worth of tutorials and references scattered around the web, many of them for
out of date versions of the toolkit.
You are trying to use SLEPc functionality, so you should start with their
documentation: http://www.grycap.upv.es/slepc/documentation/manual.htm
and its user manual: http://www.grycap.upv.es/slepc/documentation/slepc.pdf
In the case of PETSc, there is extensive documentation available from here:
http://www.mcs.anl.gov/petsc/petsc-as/documentation/index.html
You should start with the user manual:
http://www.mcs.anl.gov/petsc/petsc-as/snapshots/petsc-current/docs/manual.pdf
 A
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110802/05100b0b/attachment.htm>
