[petsc-users] race conditions in VecSetValue(s)
Barry Smith
bsmith at mcs.anl.gov
Mon Aug 1 16:05:48 CDT 2011
On Aug 1, 2011, at 2:59 PM, Dominik Szczerba wrote:
> What will happen if VecSetValue(s) called from different processes
> want to update the value at the same position in the global MPI
> vector?
> Is there a some sort of queue/lock
No
> or will a race condition result?
No.
> It's not discussed in the documentation.
Yes it is :-)
If ADD_VALUES is used then the location will always get the correct sum.
If INSERT_VALUES is used then one of the values set will be used but it is not defined which one.
Barry
> Thanks for any clarification,
> Dominik
