[petsc-users] SLEPc generalized eigenvalue problem question?
Matthew Knepley
knepley at gmail.com
Mon Aug 1 13:41:42 CDT 2011
On Mon, Aug 1, 2011 at 6:36 PM, John Chludzinski <jchludzinski at gmail.com>wrote:
> These are definitely not dense matrices (>99% zeros).
> The way I described storing them just happened to be a way I found that
> worked (for EPS = LAPACK). But I want to use methods intended for sparse
> matrices + MPI.
> Which is the best canonical PETSc form (for the matrices) and best EPS?
1) MATAIJ
2) What is EPS?
Matt
> ---John
> On Mon, Aug 1, 2011 at 2:27 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Aug 1, 2011 at 6:22 PM, John Chludzinski <jchludzinski at gmail.com>wrote:
>>> I'm a newbie with both PETSc & SLEPc and have had some trouble finding
>>> examples/tutorials for newbies. I've looked through the examples in the
>>> PETSc and SLEPc directories but still am having "issues" seeing how to set
>>> this up for the type of problem I have.
>>> SLEPc ex7.c is a good place to start but there's still how best to store
>>> the matrices and which EPS to use (besides LAPACK).
>>> Found a PDF, "MATRICES IN PETSc", (after much googling) but not sure
>>> which of the many forms will work and which is best.
>> 1) PETSc and SLEPc are designed to be efficient for sparse matrices. If
>> you want eigenvalues of dense matrices, use Elemental (as I pointed out in a
>> previous message)
>> 2) If you generate matrices with C code, why not just call MatSetValues()
>> for each row in that code?
>> Matt
>>> ---John
>>> On Mon, Aug 1, 2011 at 2:12 PM, John Chludzinski <jchludzinski at gmail.com
>>> > wrote:
>>>> I have 2 files (matrices) in simply binary form (IEEE-754, generated by
>>>> some C code) and wished to get them into canonical "PETSc binary form". So I
>>>> did:
>>>> Mat A;
>>>> PetscScalar *a;
>>>> ierr = PetscMalloc(SIZE*SIZE*sizeof(PetscScalar),&a);CHKERRQ(ierr);
>>>> // stored the file into the space malloc'ed for 'a'.
>>>> MatCreateSeqDense(PETSC_COMM_SELF, n, n, a, &A);
>>>> MatView(A,PETSC_VIEWER_BINARY_(PETSC_COMM_WORLD));
>>>> This works when I use: -eps_type lapack. As long as I store the matrix
>>>> in column major order.
>>>> ---John
>>>> On Mon, Aug 1, 2011 at 1:40 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Mon, Aug 1, 2011 at 5:27 PM, John Chludzinski <
>>>>> jchludzinski at gmail.com> wrote:
>>>>>> I create 2 matrices using:
>>>>>> MatCreateSeqDense(PETSC_COMM_SELF, n, n, Ka, &A);
>>>>>> MatCreateSeqDense(PETSC_COMM_SELF, n, n, Kb, &B);
>>>>>> These matrices are 99% zeros ( 16,016,004 entries and 18660
>>>>>> non-zeros). They are symmetric and real. Their tri-diagonal elements are
>>>>>> non-zero plus a few other entries.
>>>>> Please give some justification for doing this? On the surface, it just
>>>>> seems perverse.
>>>>> Matt
>>>>>> I tried to use ex7 for the generalized eigenvalue problem:
>>>>>> ./ex7.exe -f1 k.dat -f2 m.dat -eps_gen_hermitian -eps_smallest_real >
>>>>>> x.out 2>&1
>>>>>> without specifying an EPS and get:
>>>>>> Generalized eigenproblem stored in file.
>>>>>> Reading REAL matrices from binary files...
>>>>>> Number of iterations of the method: 500
>>>>>> Number of linear iterations of the method: 4009
>>>>>> Solution method: krylovschur
>>>>>> Number of requested eigenvalues: 1
>>>>>> Stopping condition: tol=1e-07, maxit=500
>>>>>> Number of converged approximate eigenpairs: 0
>>>>>> Is krylovschur inappropriate for this problem or have I set up the
>>>>>> problem incorrectly by using MatCreateSeqDense(...) to create the matrix
>>>>>> input files in PETSc binary form?
>>>>>> ---John
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110801/57ea4f33/attachment.htm>
