[petsc-users] SLEPc generalized eigenvalue problem question?
    John Chludzinski
    jchludzinski at gmail.com
    Mon Aug  1 13:12:45 CDT 2011
I have 2 files (matrices) in simply binary form (IEEE-754, generated by some
C code) and wished to get them into canonical "PETSc binary form". So I did:
Mat A;
PetscScalar *a;
ierr = PetscMalloc(SIZE*SIZE*sizeof(PetscScalar),&a);CHKERRQ(ierr);
// stored the file into the space malloc'ed for 'a'.
MatCreateSeqDense(PETSC_COMM_SELF, n, n, a, &A);
MatView(A,PETSC_VIEWER_BINARY_(PETSC_COMM_WORLD));
This works when I use: -eps_type lapack.  As long as I store the matrix in
column major order.
---John
On Mon, Aug 1, 2011 at 1:40 PM, Matthew Knepley <knepley at gmail.com> wrote:
On Mon, Aug 1, 2011 at 5:27 PM, John Chludzinski <jchludzinski at gmail.com>wrote:
>> I create 2 matrices using:
>> MatCreateSeqDense(PETSC_COMM_SELF, n, n, Ka, &A);
>> MatCreateSeqDense(PETSC_COMM_SELF, n, n, Kb, &B);
>> These matrices are 99% zeros ( 16,016,004 entries and 18660 non-zeros).
>>  They are symmetric and real.  Their tri-diagonal elements are non-zero plus
>> a few other entries.
> Please give some justification for doing this? On the surface, it just
> seems perverse.
>    Matt
>> I tried to use ex7 for the generalized eigenvalue problem:
>> ./ex7.exe -f1 k.dat -f2 m.dat -eps_gen_hermitian -eps_smallest_real >
>> x.out 2>&1
>> without specifying an EPS and get:
>> Generalized eigenproblem stored in file.
>> Reading REAL matrices from binary files...
>> Number of iterations of the method: 500
>>  Number of linear iterations of the method: 4009
>> Solution method: krylovschur
>> Number of requested eigenvalues: 1
>> Stopping condition: tol=1e-07, maxit=500
>> Number of converged approximate eigenpairs: 0
>> Is krylovschur inappropriate for this problem or have I set up the problem
>> incorrectly by using   MatCreateSeqDense(...) to create the matrix input
>> files in PETSc binary form?
>> ---John
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110801/6200a0ad/attachment.htm>
