[petsc-users] about pclu
Matthew Knepley
knepley at gmail.com
Tue Apr 5 22:27:03 CDT 2011
On Tue, Apr 5, 2011 at 10:20 PM, Ryan Yan <vyan2000 at gmail.com> wrote:
> One more ask, :-)
> Which one is more efficient, richardson, preonly or no difference, if I am
> going to use direct solver for many times steps.
There should be no difference since direct solves take so long.
Matt
> Thanks,
> Yan
> On Tue, Apr 5, 2011 at 11:06 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Apr 5, 2011, at 9:52 PM, Ryan Yan wrote:
>> > Hi,
>> > I am wondering is there a way of checking the residual of a direct
>> solver. It should
>> > be one shot and very small. I tried -ksp_monitor_true_residual, but no
>> thing shows up. I guess a piece of code
>> > $Ax-b$ will do the trick?
>> The reason that the monitor doesn't display anything is not the direct
>> solver but because you are using LU with KSPType of KSPPREONLY if you run
>> with -ksp_type richardson or -ksp_type gmres then -ksp_monitor_true_residual
>> will print the residual as you want.
>> Barry
>> > Thanks,
>> > Yan
What most experimenters take for granted before they begin their experiments
is infinitely more interesting than any results to which their experiments
lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110405/8fabf337/attachment.htm>
