[petsc-users] about pclu
Ryan Yan
vyan2000 at gmail.com
Tue Apr 5 22:16:05 CDT 2011
Dear Barry and Matt,
Thanks for the help,
Indeed, the monitor starts to work with "richardson".
Yan
On Tue, Apr 5, 2011 at 11:06 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Apr 5, 2011, at 9:52 PM, Ryan Yan wrote:
> > Hi,
> > I am wondering is there a way of checking the residual of a direct
> solver. It should
> > be one shot and very small. I tried -ksp_monitor_true_residual, but no
> thing shows up. I guess a piece of code
> > $Ax-b$ will do the trick?
> The reason that the monitor doesn't display anything is not the direct
> solver but because you are using LU with KSPType of KSPPREONLY if you run
> with -ksp_type richardson or -ksp_type gmres then -ksp_monitor_true_residual
> will print the residual as you want.
> Barry
> > Thanks,
> > Yan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110405/bbbd6483/attachment.htm>
