[petsc-users] [Fortran] subroutines inside modules?
    Leo van Kampenhout
    lvankampenhout at gmail.com
    Thu Sep 30 17:09:53 CDT 2010
Declaring it external in the program/subroutine that is using the module
results in
main.F:65.43:
      external gridtest
Error: Cannot change attributes of USE-associated symbol at (1)
Thanks, Leo
2010/9/30 Stephan Kramer <s.kramer at imperial.ac.uk>
> On 30/09/10 15:31, Leo van Kampenhout wrote:
>> Hi all,
>> since it is mandatory to declare all subroutines as "external" in
>> Fortran, is it possible for Modules to have subroutines? I'm unable to
>> declare the subroutine external inside the module itself, nor in the
>> program which is using it. Not declaring it external at all results in
>> the following compilation error:
>> /net/users/csg/csg4035/master/workdir/src/main.F:97: undefined reference
>> to `__grid_MOD_readgrid'
>> (the module is here is named "grid", the subroutine "readgrid" )
>> Thanks,
>> Leo
> If you put your subroutine in a module, it should not be declared
> external. You can directly call it from within the module itself. When
> calling it inside any other module/program you need to add "use grid"
> before
> the "implicit none".
> Putting subroutines inside a module is highly recommended as it
> automatically
> provides an explicit interface so that the compiler can check the arguments
> in
> your subroutine call.
> Cheers
> Stephan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20101001/99fc02b5/attachment.htm>
