[petsc-users] petsc4py
Николай Кутузов kutuzovnp at gmail.com
Thu Sep 30 13:26:20 CDT 2010
how should i use that patch?
2010/9/30 Jed Brown <jed at 59a2.org>
> On Thu, Sep 30, 2010 at 19:35, Jed Brown <jed at 59a2.org> wrote:
> >> ts.setIFunction(ode.evalFunction, f) --->
> ts.setIFunction(ode.evalFunction)
> > This won't work, you need to provide a residual vector, otherwise
> > PETSc does not know how large your vector is
> Actually, you have to set the initial vector somewhere, and the
> residual vector can be obtained by duplicating it.  PETSc works this
> way in C.  Lisandro, why does TS.setIFunction require the residual
> vector to be provided?  If you agree that it's not necessary, please
> apply the attached patch.
> Jed
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20100930/d54410e2/attachment.htm>
